Author Topic: post your rig  (Read 14983 times)
Offline .:.Dingman.:.
Re: post your rig
« Reply #15 on: November 30, 2008, 12:01:00 AM »
yummy
Offline barmanjay
Re: post your rig
« Reply #16 on: November 30, 2008, 12:22:56 AM »
I think you are missing a couple things lance,.. :D
The realtor that gets dirty
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
Offline Mudhawg
  • Rig Life
Re: post your rig
« Reply #17 on: November 30, 2008, 01:20:18 AM »
ohhhh Rockwells?  ;D go big or go home
Offline dubbleJs
Re: post your rig
« Reply #18 on: November 30, 2008, 02:01:13 PM »
Here's my bumperless sack.
Re: post your rig
« Reply #19 on: December 01, 2008, 09:22:49 AM »
03 rubi
Spydertrax 609's front and rear, detroits, 538's, 35 spline everything
Custom linked w/ 14" coilovers
4.5l long rod stroker to NV4500, to 2.72:1 Klune V underdrive, to atlas 2:1
38's on trailready beadlocks
HMFI
Re: post your rig
« Reply #20 on: December 28, 2008, 11:48:32 PM »
Bnine - I could almost see my rig in your first pic, but seems how I can't I'll post a few.
89 MJ, D60, Sterling 10.25, Detroits, 5.38's, Atlas 4.3, NWF Black Box 2.7:1, 39.5 TSL's, H1 double bead locks,winch front/back, Premier welder, and lot's of stuff in the box. ;)
Offline Gearhead
Re: post your rig
« Reply #21 on: December 29, 2008, 11:12:30 AM »
88 YJ
4.7 l   twelve counterweight , short rod stroker , ported n' polished , balanced , Rubicon express 62 mm throttle body , 24 lb / hr Accel injectors, comp cams valvetrain , Banks header w/ full stainless exhaust , K&N cold air intake , 98 external slave AX15 /  NP231 w/ AA slip yoke eliminator , M.O.R.E. 1" motor mount lift w/ bomb proof block bracket kit , 1" body lift , Rubicon express 4.5" extreme springs , Rubicon express Long travel shocks w/ remote gas reservoirs , Wagoneer Dana 44 's   F&R  w/ 4.56 gears , true trac in the front , Detroit locker in the rear , All  Warn 4140 alloy shafts in the front  w/ Warn premium hubs , Disc brake conversion on the rear , one ton brake master cylinder , Full roll cage , Mastercraft seats and five point belts - mounted to the cage , Viar onboard air w/ dual  air tanks , Warn 9.5 TI winch , Cobra CB  , Garmin GPS , Sony am fm  ten disc CD , Rockford Fosgate amp & 10" sub , Front and rear auxillary  halogen lighting , Hand crafted bumpers  , steering box brace , rock rails  n' tire carrier ,  36 - 13.50 bias ply Irocs on 15 x 10 Allied beadlocks  OR  35 - 12.50 Goodyear MTR 's on 15 x 8   Black steel , hand crafted tire chains , Four wheel Mico lock parking brake w / all stainless braided premium plumbing n' hardware , Bushwacker fender flairs , full complement of recovery ,  emergency , repair & survival gear  , half doors , full doors , soft doors   and more .......
Favourite mod ? converting to fuel injection !
For a twenty one year old rig , it works OK  &  gets there n" back , often without breaking .
« Last Edit: December 29, 2008, 02:00:29 PM by Gearhead »
Offline cablesmurf
  • Relapsed Jeep Addict
Re: post your rig
« Reply #22 on: December 30, 2008, 02:01:53 PM »
For me, that's one of the nicest YJ's I have ever seen...
Re: post your rig
« Reply #23 on: December 30, 2008, 04:15:48 PM »
1997 TJ Sahara
ARB front & rear
rear spidertrax hi pinion 609
front hi pinion dana 30/44 hybrid w/ warn hubs
upgraded 4 wheel disc brakes (4 piston rears)
03 rubicon nv3550 5 speed
17" walker evans beadlocks
35" toyo open country e-rated tires
warn 9000
dual optima batteries
needs a lot more... cosmetic stuff .. ie bumpers and rocker stuffs.  antirock installed.
Offline Mudpig97
Re: post your rig
« Reply #24 on: January 03, 2009, 06:04:08 PM »
Well heres mine...not much of a list of mods though.  85CJ7  4.2liter t-5 and dana 300.  Sittin on toyota axles with 3.90 gears and a welded rear.  Custom d/shafts, 35"mud tires on 10" white spokes, custom(homemade) front bumper rear to come.  3" rancho springs with SOA and high steer.  Mustang gt seats, cobra cb, stereo and more to come...
« Last Edit: January 03, 2009, 10:17:54 PM by XJHERO »
85 CJ7, toy axles and 35's, miller locker in rear.
Offline fug
  • Airdrie Pick n Pull
Re: post your rig
« Reply #25 on: January 04, 2009, 07:56:03 PM »
The latest Jeep to follow me home... 1988 YJ with 4.2, 5 speed... bone stock from what I can tell.  I think I'm winning the Jeep parking lot competition  :P ::) :P  LOL thankfully my neighbours are pretty understanding.
Fug
TJ Rubicon
Re: post your rig
« Reply #26 on: January 04, 2009, 09:31:51 PM »
Fug: what are the specs on that ZJ there
Offline fug
Re: post your rig
« Reply #27 on: January 04, 2009, 09:41:08 PM »
The black ZJ is a 93 with a 4.0, auto, and a 242 T-case.  The tranny is suposedly bad but I haven't had to time to look to deeply into it.  It drove onto the trailer and off... but suposedly after driving a while it starts to slip badly and won't move anymore.
There's another ZJ behind the fence that's a 94 with a rare 4.0, 5 speed combo.  Engine has real low compression so my plan was to part out the 93 and put the engine from it in the 94.
Fug
TJ Rubicon
Re: post your rig
« Reply #28 on: January 04, 2009, 09:50:26 PM »
How the hell can your neighbors be so understanding fug? even I don't understand, and I have 4!!
(yes you are winning)
T
Offline fug
Re: post your rig
« Reply #29 on: January 04, 2009, 09:56:00 PM »
The way my lot is situated only a couple of houses can even see my garage/collection of Jeeps so that helps a lot I think.   I don't plan to keep this many around forever.  If the weather would cooperate and I get some time ... I'll be parting out one of the ZJ's and possibly one of the XJ's as well.
Fug
TJ Rubicon
