Author Topic: Air Cond. Pump Removal  (Read 2458 times)
Offline jandh
« on: May 18, 2009, 08:23:10 PM »
Has anyone Removed there air conditioning pump from there 4.0L engine and changed the serpentine belt?
Did this on a mustang of mine a few years back and was wondering if anyone has done it to a cherokee
1991 YJ
FullMetalJeep
Re: Air Cond. Pump Removal
« Reply #1 on: May 18, 2009, 08:48:02 PM »
are you going to remove the AC?
cause if you dont want to use it, you can just bypass it with a serpentine belt from another cherokee w/o AC. Thats what I did.
FullMetalJeep
« Reply #2 on: May 18, 2009, 09:09:11 PM »
here is the part # for a smaller belt to bypass your A/C:
NAPA P# 25060790
This should be the one, but check at Napa to make sure.
Another idea is you could remove it for extra space under the hood, or spend money and just turn it into on board air.
Offline jandh
« Reply #3 on: May 18, 2009, 09:21:30 PM »
On board air?   sounds interesting tell me more
1991 YJ
« Reply #4 on: May 18, 2009, 10:33:52 PM »
Don't forget to properly recover the freon.... don't want a huge fine.....
FullMetalJeep
« Reply #5 on: May 19, 2009, 09:42:08 AM »
here is a link to a conversion on a TJ, but should be basically the same for your strait six. CLICK
There is a company who sells all the parts needed to do it. and many more builds on the net as well as in JP mag (check their site). The only reason anyone should fix their A/C is because theyre doing an air compressor conversion.
FullMetalJeep
« Reply #6 on: May 19, 2009, 09:49:17 AM »
Caddy
« Reply #7 on: May 20, 2009, 05:20:00 PM »
http://www.jeepforum.com/forum/showthread.php?t=471962
saw this thread as I am looking to do the same thing in my cherokee. I will probably pick up all the parts this weekend.
except a tank I still need to find one for cheap!
Offline jandh
« Reply #8 on: May 20, 2009, 06:13:36 PM »
There's no freon left in it now, that why i was looking at bypassing it.  but the on board air looks very appealing.
1991 YJ
Offline jandh
« Reply #9 on: May 20, 2009, 06:14:06 PM »
Thanx Caddy , thats a perfect post.  this is what i will be doing
1991 YJ
Caddy
« Reply #10 on: May 20, 2009, 06:52:54 PM »
Np, hope it helps I know it cleared up alot of questions for me. It's a great article!
« Reply #11 on: May 20, 2009, 11:22:10 PM »
OBA for sure if your a/c system is hooped.
Offline jandh
« Reply #12 on: May 21, 2009, 07:32:00 AM »
if i remember correctly the clutch on the front of the pump doesn't engage either.  is that an easy fix??
1991 YJ
Offline esi
« Reply #13 on: May 21, 2009, 07:59:16 AM »
if there is a pressure switch in the system, the clutch on te compressor won't engage if the system has drained down. Jump a wire straight to the compressor and see if it will engage then.
Formerly of Boots & Boost Inc
« Reply #14 on: May 21, 2009, 07:31:42 PM »
jump it out without the engine running.... you won't rip a sleeve or anything worse. ;)
