Author Topic: Xj steering box inner brace  (Read 2007 times)
KrossLoch Fab
« on: May 27, 2009, 12:05:24 PM »
Please see the link on EJC.
(I need tutoring on posting pics on this site!!!)
http://edmontonjeep.com/forum/viewtopic.php?f=28&t=7371
Offline dubbleJs
Re: Xj steering box inner brace
« Reply #1 on: May 27, 2009, 05:45:17 PM »
Should be the same to post pics on EJC, host your photos on a site like photobucket.com,then copy the link here and press the little IMG tag in the reply screen...insert the copied link inbetween the IMG tags.
« Reply #2 on: May 27, 2009, 06:24:30 PM »
Make sure people use the outer bumper tabs as well. On my old XJ I pulled the heads of the bolts THRU the unibody!
KrossLoch Fab
« Reply #3 on: May 27, 2009, 06:26:44 PM »
Good advice my friend!
« Reply #4 on: May 27, 2009, 06:27:58 PM »
Here you go Craig...
It would be also good if you would find a way to sleeve the holes that the 3 steering bolts goes through from side to side of the unibody... and weld the sleeve on both reinforcement plates.... there is a 4/3" to 1" hole that goes through the unibody a bit closer to the shock. You could put a rod through that also and weld it on both reinforcement plates also.  Roseweld the crap out of both plates and box it in with a little plate on the underside on the unibody...
I have the JKS version of of that... that's what they do and it's it solid as a bastard.
This is a great mod for an XJ... the unibody is prone to crack where the steering ... Nice Job!! ;D
KrossLoch Fab
« Reply #5 on: May 27, 2009, 08:57:00 PM »
Awesome! That is an cool mod too! Thx Swampsinger!
