Author Topic: cb help  (Read 1611 times)
Offline .:.Dingman.:.
cb help
« on: September 16, 2009, 08:14:59 PM »
where would I buy a swr meter on the cheap? or can anybody tune my cb (I'm in northeast calgary)
Dingman
90YJGIMP
Re: cb help
« Reply #1 on: September 16, 2009, 08:17:54 PM »
I ordered one from radioworld.ca , about $30.00.
Re: cb help
« Reply #2 on: September 16, 2009, 08:52:32 PM »
Perfect so you'll let me borrow it for like 30 minutes for 10 dollars?
Re: cb help
« Reply #3 on: September 17, 2009, 08:24:37 AM »
you should still consider buying one, off ebay or wherever.  you should really test your SWR every month or so, especially when wheeling.
cables, connections and antennas get beat up pretty good on the trails and SWR is usually the only way to know things are ok.
if they get broken and you don't test or realise, the radio won't last long.
Offline jeeptastic
Re: cb help
« Reply #4 on: September 17, 2009, 08:44:51 AM »
What does a SWR Meter do?
Re: cb help
« Reply #5 on: September 17, 2009, 08:53:10 AM »
it measures the percentage of your radio signal output from the antenna.  if your radio and antenna are not tuned to the vehicle, you will get feedback from the antenna back into the radio.  cb radios are only 4 watts so every percentage helps.
also lots of feedback can shorten the lifespan of the radio.  sometimes drastically.
http://www.firestik.com/Tech_Docs/Setting_SWR.htm
and the complete FAQ
http://www.firestik.com/Tech_Docs.htm
Re: cb help
« Reply #6 on: September 17, 2009, 11:01:54 AM »
Thanks FiEND I guess I'm picking one up soon.
Dingman
Offline Elsifer
Re: cb help
« Reply #7 on: September 18, 2009, 09:50:15 AM »
http://www.ntfc.ca
They are in the NE, by the Husky truck stop on 32nd and Barlow, MFJ-822, 1.8-200 Mhz, like $30 or so. It'll test your CB, and if you get into Amateur Radio, it'll test everything important (nobody uses UHF anyways ;) )
VA6CPL
Jeepless....
Offline S-FLY
  • '94 XJ
Re: cb help
« Reply #8 on: September 21, 2009, 07:58:43 AM »
I have one but I'm located downtown.
ve1sly
Re: cb help
« Reply #9 on: September 23, 2009, 12:25:06 AM »
Thanks fly but I picked one up from vince
