Author Topic: Winter Builds?  (Read 11897 times)
Re: Winter Builds?
« Reply #15 on: October 15, 2009, 11:36:18 PM »
Sort of.... :)
Offline Waytec
  • not all there
Re: Winter Builds?
« Reply #16 on: October 16, 2009, 08:57:18 AM »
everyone will just have to wait until spring when it is done.  ;D
The obstacle is the path.
Offline mike s
  • Good times!
Re: Winter Builds?
« Reply #17 on: October 16, 2009, 09:22:32 AM »
Flat fenders should be here in a week or so...rear corners. sliders, front & rear fenders. Anyone have experience with Gen Right stuff?
oldEnuff2NObetter
but still can't help myself
Offline muffintop
  • You spilled my macchiato!
Re: Winter Builds?
« Reply #18 on: October 16, 2009, 06:17:36 PM »
What size flares did ya go with? Any plans for bigger rubber?
2014 Jeep SRT
Offline mike s
  • Good times!
Re: Winter Builds?
« Reply #19 on: October 16, 2009, 08:59:02 PM »
Looking for complete tire coverage and less mud inside open jeep so went with 6" wide flares.
oldEnuff2NObetter
Offline Eagle Jeeper
Re: Winter Builds?
« Reply #20 on: October 16, 2009, 09:23:48 PM »
Here she is as I found it
Here it is as I got it home.
When it came home I found the motor to be stuck, filled the cylinders with ATF and left it for five weeks and she cranked over right away tonight so now I'm hot and bothered to get it on the road. A few nights in the shop, plugs, fluids, and filters later and hopefully it will be good to go.  Spend the rest of the winter tinkering to make it a DD.
« Last Edit: October 16, 2009, 09:25:56 PM by Eagle Jeeper »
Offline i_go_commando
Re: Winter Builds?
« Reply #21 on: October 18, 2009, 05:05:47 AM »
ah i like the fullsize jeep pickups, ah heck even the old waggoneers are kinda neat
my list involves finsih rewiring the fc, cut the back of the cab of and weld on a new one and strecth the frame slightly to acoomodate the box to fit back on. after that, inspection and drive er. oh and maybe some more tremclad paint.
if i have time then i should put the wiring in the commando back together and get that running gear going too...
Offline dac
Re: Winter Builds?
« Reply #22 on: October 19, 2009, 02:54:45 PM »
I'm thinking a re-gear and some sort of traction aiding device is in order.  Possibly rock sliders as well..... and a new air freashener...... and oil change.
Offline Rodjock
  • Drives the Jeep of Awesomeness
Re: Winter Builds?
« Reply #23 on: October 19, 2009, 03:12:02 PM »
On the list:
Outer axle seals
front anti-rock system
Thick coat of wax
maybe a tummy-tuck
little bit of lift
more wax
possibly a liner for the hard top
headlight covers
additional wax
will consider CB relocation
rear bumper
thinking about a new front bumper
all to be done sometime in between wheeling and adding a coat of wax.
« Last Edit: December 09, 2009, 11:15:07 PM by Rodjock »
Offline Waytec
  • not all there
Re: Winter Builds?
« Reply #24 on: November 04, 2009, 11:04:17 PM »
So is the wax for your legs, Doms back or the TJ
Re: Winter Builds?
« Reply #25 on: November 04, 2009, 11:17:45 PM »
Mine is secret and wont be done until next spring or summer, depending on where I work
Offline Rodjock
Re: Winter Builds?
« Reply #26 on: November 05, 2009, 07:24:36 AM »
Well... it was for the TJ, however when you put it that way......
Offline Aspirated
Re: Winter Builds?
« Reply #27 on: November 05, 2009, 08:21:10 AM »
Mods
-Front Bumper w/ winch (Warn)
-Flood Lights (Light Force)
Repairs
-Tranny replacement AX-15  (anyone have one?)
-Clutch Master Cyl.
-Maybe that Mopar Stroker 4.7L (trying to button down cost and Parts number)
Freshen up the inside - change center console (broken lid) - speakers for stereo
I was going to go to work on the axles but figured id spend that cash when they break.
1998 XJ
2008 KK
Offline mike s
  • Good times!
Re: Winter Builds?
« Reply #28 on: November 05, 2009, 04:09:48 PM »
parts over a week late, try back in 10-12 more days, wtf?
oldEnuff2NObetter
Offline Mudhawg
  • Rig Life
Re: Winter Builds?
« Reply #29 on: November 05, 2009, 04:58:52 PM »
New motor (mine just told me to screw myself)
Weld on beadlocks
