Author Topic: Winter Builds?  (Read 11894 times)
Offline .:.Dingman.:.
Re: Winter Builds?
« Reply #30 on: November 06, 2009, 09:24:29 AM »
400sb, 4-6 drop, c notch, 4:10 or 3:73 gears, fix the rust, long story short frame up restoration with a bunch of mods.
Offline Waytec
  • not all there
Re: Winter Builds?
« Reply #31 on: November 10, 2009, 05:44:17 PM »
It has started.
Step one done. Going for step two tonight.
The obstacle is the path.
Offline 2grand4u
Re: Winter Builds?
« Reply #32 on: November 10, 2009, 08:50:42 PM »
all my part just came in so my fun has started, i want to have it done for the run on the 28th
Offline muffintop
  • You spilled my macchiato!
Re: Winter Builds?
« Reply #33 on: November 16, 2009, 04:01:58 AM »
parts over a week late
Only a week? Your just getting started. I'd make a snack and turn on the TV ;)
2014 Jeep SRT
Offline Justink
  • '89 comanche 5'' lift, 33's
Re: Winter Builds?
« Reply #34 on: November 16, 2009, 07:47:18 AM »
got another cherokee ;D.  put in a motor, need to regear, maybe a 8.25 if i can find one cheap enough looking for 4.10's for a dana 35 and dana 30 if anyone has some.
Justin
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
Offline mike s
  • Good times!
Re: Winter Builds?
« Reply #35 on: November 16, 2009, 09:39:14 AM »
parts showed but wrong ones so back to 3-4 weeks waiting...sigh. need to change supplier i think.
oldEnuff2NObetter
but still can't help myself
Offline Pookapotamus
Re: Winter Builds?
« Reply #36 on: November 16, 2009, 10:41:02 AM »
ok i have been late posting here because my budget looks like crap! but i just got word from Mrs pook that if i pay off my credit card i can max it out in the spring!  ;D
so here is what i am looking at,
set of 32" bfg's
rims
5-6" re lift (to clear my low rider name)
hesco adjustable fuel pressure regulator (to fix my low psi problems)
body work (to fix my rusting issues)
timing chain (to help freshen up the tired 4.0L)
jack all
tire deflators
on board air
snatch block
electric fan
better reverse lights
tranny cooler (yes noel i still want it)
and anything else i can get my hands on before Mrs Pook tightens the reigns.
and for Mrs. pook's xj:
tires and lift from mine.
and figure out why the bloody check engine light always comes on.
Offline Gearhead
Re: Winter Builds?
« Reply #37 on: November 17, 2009, 10:01:12 PM »
Demolish and renovate bathroom on the main floor.
Gut and renovate master bedroom.
Overhaul  Laundry / utility room.
Misc. ceramic tile work .
Misc. painting as reqd.
Misc. lighting fixtures as reqd.
Re  shingle garage.
NO   jeep work   for a while .
And so on   ..............................................
Re: Winter Builds?
« Reply #38 on: November 17, 2009, 10:17:31 PM »
Hmmm....which one?
1)02 KJ - new tires....maybe front tow points and install the hitch
2)89 MJ - just received 31's, CB,  and Rocky Mountain pinstriping.  97+ header facelift, possible 2" additional lift, 2x4 steel slider/running boards instead of rockers, CB antenna permanent mount, and needs new interior including floors.
3)54 CJ3B - basket case.  Needs everything.  No wait....I think the spring hangers are still on the frame.
4) 48 CJ2A - engine is pulled, Chevy 4.3 lurks in the corner waiting to take advantage of my jeep in its emotionally fragile and needy state right now. Tub is going to be pulled, hopefully new corners welded in, lockers hooked up, new shocks, new spring.
5) Human cloning to get all this done.
Offline after6queers
  • BANNED
Re: Winter Builds?
« Reply #39 on: November 18, 2009, 07:29:09 PM »
YJ ~ downgrade to 35s. take 2" body lift out of YJ. get it nice and low (to high for me to get in, sick of losing beltloops on my pants ;) )
I lose belt loops all the time I thought it was because I am too fat but maybe there is another reason!!! Woohoo off to the pantry for some Chips Ahoy!!
2001 Jeep TJ - 4" Lift 35's MTZ Chanda made bumpers, fenders and sliders...still working on her!!!
Re: Winter Builds?
« Reply #40 on: November 19, 2009, 12:58:08 AM »
Long lists.  :o
Ours isn't too long...yet...
Exterior stucco or siding (current 1969 vintage siding is on it's last legs)
Gut and reno upstairs bathroom
Replace back fence
Could be a lot worse, all things considered. It won't all be happening this winter...that bathroom is a "maybe", the other two will have to wait. Especially the $tucco idea.
Offline copperheadj20
Re: Winter Builds?
« Reply #41 on: November 22, 2009, 12:39:14 PM »
I just finished cramming a cummis 12 vave into my YJ with divorces 205, dana 60 front and rear just working on some custom 4 links.
Offline WagoneerXJ
  • Bagon Wagon!
Re: Winter Builds?
« Reply #42 on: November 22, 2009, 03:18:30 PM »
hmm where do I begin...
98 XJ DD:
- Tear out rear springs again, and the stupid lift blocks. Throw in the S-10 springs I have with new u-bolts.
- Install Rusty's T-Case Drop
- Wire up Pro Comp lights that came with the roofrack
- Wire up new trailer hitch
- Purchase and install Nates4x4.com front bumper
99 XJ project
- fix part of front rad support
- find passenger side fender
- paint both fenders to match
- find new or fix old header panel
- new windshield
- adjust latch on rear hatch
89 MJ "Trailer"
- Tear out old bent/broken leaf springs, replace with donors from an 88.
- make tongue for the front
- wire up tail and brake lights
- swap tailgates
- re-mount bed
- paint
- find 2 more matching rims
84 Mustang GT-Built 351W 5spd
Re: Winter Builds?
« Reply #43 on: December 06, 2009, 01:56:33 PM »
well since a few people have asked about my jeep i may as well post up. im turnng my jeep into a pile of parts, removing the crappy pieces and adding some gooder pieces. thats it. i was goin to post some pics but it wouldnt let me, your loss, not mine 8)
Re: Winter Builds?
« Reply #44 on: December 06, 2009, 08:19:23 PM »
Are you keeping that cute lil teddy bear stuck to your dash Eric? Awwwww.... :-*
I'm surprised that you still have all those National decals on your Jeep.
There is a sticky that tells you how to post pictures on this site. Give it a read. Good luck with your project, and I hope it gets done in time for some winter wheeling.
