Author Topic: 2 YJ's at PNP  (Read 4722 times)
1988 Cherokee
2 YJ's at PNP
« on: February 01, 2010, 11:42:22 PM »
I saw 2 YJ's at pick and pull today
Re: 2 YJ's at PNP
« Reply #1 on: February 02, 2010, 09:34:22 AM »
Thanks bud... good to know!
1988 Cherokee
Re: 2 YJ's at PNP
« Reply #2 on: February 04, 2010, 04:39:31 PM »
Not a problem at all, just thought I would give you all a heads up on what I saw there. They had their hardtops still on.
There is a 81 fullsize cherokee pretty complete there as well.
« Last Edit: February 04, 2010, 04:45:14 PM by 1988 Cherokee »
Re: 2 YJ's at PNP
« Reply #3 on: February 04, 2010, 09:03:36 PM »
Any idea if it was a wide trac with the fender flares?
1988 Cherokee
Re: 2 YJ's at PNP
« Reply #4 on: February 06, 2010, 12:32:38 AM »
I  am unsure, I can tell you it had very long front hubs that stuck out. It had the AMC engine. Cant remember the flares.
I will most likely be there again tomorrow, if you can tell me what to look for I can get back to you.
Re: 2 YJ's at PNP
« Reply #5 on: February 06, 2010, 01:35:56 AM »
A wide trac model will have some plastic/rubber flares on the fenders and may or may not have a wide trac decel on the back. I need the inner axle shafts from the front diff.
Offline 4Banger_madness
Re: 2 YJ's at PNP
« Reply #6 on: February 07, 2010, 10:56:38 AM »
there was actually 2 full size jeeps there yesterday the yjs where still there one top was gone and one tub was gone someone took three springs out of one it had aftermarket shackles but only one was left
1988 Cherokee
Re: 2 YJ's at PNP
« Reply #7 on: February 07, 2010, 11:47:29 AM »
That 2nd one is a new one, where abouts was that located?
The one I saw was a 2 door 4 rows in from the entrance, in the truck section.
Re: 2 YJ's at PNP
« Reply #8 on: February 07, 2010, 07:18:38 PM »
truck section back row almost beside  the fence
Re: 2 YJ's at PNP
« Reply #9 on: February 09, 2010, 08:59:39 AM »
you know what years? i need to know if i should be ditchin work friday to head down there.
Offline rws
  • Stump Grinder
Re: 2 YJ's at PNP
« Reply #10 on: February 09, 2010, 09:06:14 AM »
Hey Johnnie:  Talk to Jamie, he was cutting one them apart when I talked to him last Sat.
Offline The Machinist
  • I’m with stupid!
Re: 2 YJ's at PNP
« Reply #11 on: February 09, 2010, 11:49:29 AM »
90 and 91, was still some good stuff left on Sat when we were there.
1988 Cherokee
Re: 2 YJ's at PNP
« Reply #12 on: February 10, 2010, 11:33:40 PM »
Ya there was someone taking off Rancho suspension on that blue XJ. Had some 15% BFG MT`s there.
That red one in same isle was in good shape, looked like it was parked under a pine tree for years. Interior is awesome shape.
Re: 2 YJ's at PNP
« Reply #13 on: February 11, 2010, 07:57:32 PM »
The black cherokee ia a wide track model , 2door with the wide flares , it also has a 360 with the factory quadrajet carb on it. Front axles still intact late yesterday afternoon. When you walk in at is in the first couple of rows on the left. Hope this works for you Clay.
Re: 2 YJ's at PNP
« Reply #14 on: February 11, 2010, 09:54:30 PM »
Sweet! Thanks for the info. I`ll probably try to get there tomorrow. Anybody looking for anything, I can scope it out for you....
JohnnyC, I`ll look and see if anything there has an external slave....
