Author Topic: You know you are a redneck when......  (Read 6724 times)
Offline 4PLAYZJ
« on: February 04, 2010, 09:31:48 PM »
You hang a large furnace like this by yourself , using a ladder & a tranny jack on top of scaffolding ;D
Re: You know you are a redneck when......
« Reply #1 on: February 04, 2010, 09:55:26 PM »
 ;D
I won't show some of the stupider things I did when I was younger.....
Offline Eagle Jeeper
« Reply #2 on: February 04, 2010, 10:03:22 PM »
Whatever works and as long as you have all your fingers.
« Reply #3 on: February 05, 2010, 08:30:38 AM »
did someone say tranny jack?
Offline esi
« Reply #4 on: February 05, 2010, 09:12:12 AM »
Rednecks don't have big tranny jacks and scaffolding. They'd use a rope hooked to the bumper of their pick up, threaded through holes that they shot in the rafters. You were just being ingenuous with decent tool at hand
Formerly of Boots & Boost Inc
Offline Ostego
  • Full Size Jeep
« Reply #5 on: February 05, 2010, 09:33:42 AM »
-Takes cowboy hat off-
I won't mention how I do a lot of things.   ;)
« Reply #6 on: February 05, 2010, 09:37:37 AM »
Would you mind giving the run down on that shop? Height inside, type of trusses, etc. More pics would be awesome. I'm hoping to find a new house this summer that I can build a shop at and am collecting ideas for the build.
I definatly like the pony wall, how high is it? 24"?
Offline apex
« Reply #7 on: February 05, 2010, 10:32:16 AM »
I saw that on a website once...  :o
Offline 4PLAYZJ
« Reply #8 on: February 05, 2010, 04:45:23 PM »
yes you can borrow the tranny jack Al ;)
Here are some pics of the build.  The total size will be 43 x 26 when finished. The size in the pics is 30 x 26. I poured the foundation all at once but I am building it in two peices due to moula & permitting issues.  I used an engineeered roof system because I got the TGI for cheap & it is a good way to fit a hoist in the garage & still meet the city's 15' maximum garage height.
This part was even more redneck than the furnace, who needs a crane ;D
« Reply #9 on: February 05, 2010, 06:18:43 PM »
That's pretty much what I want to do, something high enough for a hoist. Did the roof system cost much extra? What is TGI?
Thanks for the pics.
Offline 4PLAYZJ
« Reply #10 on: February 05, 2010, 06:27:37 PM »
TGI - Tongue & Groove I-Beam
The ridge beam was close to $900 delivered it is four 18" x 1.75" x 30' peices of LVL
The rest of the roof system would normally be close to $2800
I bought a couple of frieght lifts of the TGI's for cheap so it was alot less for me.
If you have the time it will be alot cheaper(just a pain in the butt) to get a development permit to build taller walls.  I didn't want to wait the 8+ weeks it would take to get the permit.
« Reply #11 on: February 05, 2010, 11:53:25 PM »
Did you price out in floor heat? I have it in my garage now and don't think I could live with out.
How are you going to add the extra 13ft? Lean to off the back and just use it for separate workshop?
Offline 4PLAYZJ
« Reply #12 on: February 06, 2010, 08:49:55 AM »
I didnt price in floor heat because I know it is very costly & I would not see a return on it in the neibourhood I live in if I ever sell my house(already close to the top of the price bracket)
The 13 foot add on will have a roof built with the same design but the walls will be dropped 9.5".  It will just look like a step in the roof not a sloped roof.
Offline sylvrinvader
  • the micro wheeler
« Reply #13 on: February 06, 2010, 09:04:28 AM »
probably a good idea not to put in floor heat cause when you go to install a hoist you could damage your heating system when you drill into the floor and that would suck. trust me this has happened to a friend not a fun repair.
Offline justchillinout
« Reply #14 on: February 06, 2010, 11:11:22 AM »
Sorry gotta pipe in on the topic:
TGI is not Tongue and Groove I - Beam.  Though that is a good one!  TGI is just the bad pronounciation of TJI, though the Tongue and Groove kinda makes sense.
Was in the Engineered wood business for a lot of years and even helped design the joists and the machines that produced your roof rafters.
The correct term is TJI (Truss Joist I - Joist), though that is like calling a bandage a Band-Aid.  Just the common usage is all, as Truss Joist pretty much invented the engineered wood I-joist.
Those rafters are actually NJ12's produced by the now defunct Nascor Inc., at least I hope they are at least NJ12's (11 7/8" depth).  I can only guess why you got them at a good deal. ;)
Sorry, way off topic.  Garage looks good though.
« Last Edit: February 06, 2010, 11:28:17 AM by justchillinout »
