Author Topic: Where can I buy steel and they cut it to?  (Read 1818 times)
1988 Cherokee
« on: March 01, 2010, 11:19:39 PM »
Just got a decent hitch from the yard, all 8 bolts stripped from years of rust, going to make my own backing plate with welded bolts.
I know they got to be that top graded bronze bolt, and will switch it from the 15mm to 9/16th
Where can I buy steel where they cut it as well?
The backing plate I got is narrow, width is about the same as 15mm bolt.  I think what I will try to do is get the backing plate the same length as the wall to wall length inside the frame rail.  Then try to think up something good to get the plate over that small hump right near the bumper.
« Last Edit: March 01, 2010, 11:21:26 PM by 1988 Cherokee »
Offline raf2379
Re: Where can I buy steel and they cut it to?
« Reply #1 on: March 02, 2010, 12:43:27 AM »
Metal Supermarket
3716-56th Avenue South East Bay 3
Calgary, AB T2C 2B5
  (403) 720-2267
Offline apeman
  • not as grumpy
« Reply #2 on: March 02, 2010, 03:32:35 AM »
i can cut , fit and drill the backing plates you need...just need an idea of what you want and hole locations, sizes etc and i can whip one up within a couple days..even weld the nuts on for ya...and for you,,hmm free sound good?
Getting grumpier every day.
