Author Topic: Waytec's 95 XJ "Grumpy"  (Read 18009 times)
Re: Waytec's 95 XJ "Grumpy"
« Reply #15 on: March 18, 2010, 09:05:47 PM »
Where did you get the switches from?
Offline Waytec
  • not all there
« Reply #16 on: March 18, 2010, 09:54:49 PM »
Finally page 2.
 I got mine though Bear at Bear Trax Outfitters 780.651.1621
The obstacle is the path.
Offline Waytec
  • not all there
« Reply #17 on: March 23, 2010, 09:05:42 PM »
So after all day Saturday and most of Sunday the switches are in and all working. This was a project that started then snow balled into fixing other issues at the same time with 4 trips to CT.
« Reply #18 on: March 23, 2010, 09:10:47 PM »
Looks sweet dude.  I took your engine for a ride out to Rocky today...I think it enjoyed getting out again for a bit.
Offline Waytec
  • not all there
« Reply #19 on: March 23, 2010, 09:20:54 PM »
Thanks it need to get once and a while.
once this one is done that s next on the projects list.
« Reply #20 on: March 23, 2010, 09:27:48 PM »
No worries.....
(looks over his shoulder)
.....there's still room in the living room here.   ;D
Offline rws
  • Stump Grinder
« Reply #21 on: March 24, 2010, 09:26:35 AM »
Lookin Good
Offline Waytec
  • not all there
« Reply #22 on: March 24, 2010, 09:34:43 PM »
Thanks Ron
I had no idea that getting verything set up and mounted was going to be so much work. but it is worth it.
« Reply #23 on: March 25, 2010, 07:13:47 AM »
Its looking really good Aaron.  Now it just needs some swampers  ;D
Offline rws
  • Stump Grinder
« Reply #24 on: March 27, 2010, 10:57:49 AM »
It's going to be alot more "Lookin Good" after this weedend. ;D ;D
Offline Waytec
  • not all there
« Reply #25 on: March 27, 2010, 10:10:57 PM »
Ya the easy buttons will not be for show anymore.
To clarify for everyone I am not getting a front locker right now. I was not going to take the dash apart agen for the front locker next winter so I ran everything now.
« Reply #26 on: March 31, 2010, 08:05:26 PM »
Thanks Ron
if its hard work then the otucome will be better. if its too easy then you're not doing it right ;D
Offline Waytec
  • not all there
« Reply #27 on: April 04, 2010, 04:32:00 PM »
It is all worth it in the end.
I got it back looks the same but does not work the same. 4.56 gears and a ARB in the rear. I had to call Trevor and ask what the all the way to the right and up gear was. I had forgot.  :D
Air system is all hooked up and no more air leaks.  :)
I missed the shake down run because my front drive shaft CV gave up on the way back from Calgary. :( Robin happens to have one so today was down to Airdrie and back.
I cleaned up the back, got rid of a bunch of stuff I have been carrying for 2 years and have never needed.
shake down run this weekend with the RDJ guys.  ;D
Offline Waytec
  • not all there
« Reply #28 on: February 06, 2011, 12:13:18 AM »
 the saga continues
from October
I have started the 2010/11 modifications ,not by chose but buy Camshaft coming out through the block circumstances.
I have been a long time starting this from when the incident happened. I moved into a rented house with a garage (or at least half a garage). The guy in the basement gets the other half.  So I have been setting that up.
Jeep in the door
Started the tear down. Hood off
Winch, lights and bumper off. Needed to cut where the fenders where welded to the bumper.
Front clip off, I cut the condenser off as well. A/C never worked and I converted the compressor over to OBA a long time ago.
Found one of the resins for the overheating issue.
I found a other failure analyses clue.
What I am thinking right now is - when I sucked the little water into the engine I stretched/strained the timing chain. It broke piled up stopping and braking the Camshaft that then exited stage left.
I will get some pics of the side of the bock folded out. right from the chain cover past the mounts.
Offline Waytec
  • not all there
« Reply #29 on: February 06, 2011, 12:26:14 AM »
So I got snowed out working in a non heated garage. Today I moved the rig to a buddies place that is heated should have the engine out shortly and lots of other things planed mostly reworking old projects, and adding one of the most newbie things but they are actually practical for where I spend a lot of time wheeling.
Pulse a somewhat snorkel
http://www.spectreperformance.com/#CATALOG.9945
