Author Topic: Specalk's front bumper build  (Read 21254 times)
« on: June 06, 2010, 07:44:28 PM »
To start - a big thanks to Pook for all the work he has done on this bumper.   The initial designs took some time and the final drawings came out really nice.
I got the ideas for the bumper from a number of different models I've seen out there.  I really like the JK bumpers with the integrated driving lights.  I picked up some 4" PIAA driving lights for that.  I also got a couple VisionX dual LED spots to really light up the night.
The goal was to integrate the lights into bumper.
Here are a couple images from the final CAD drawings.
Re: Specalk's front bumper build
« Reply #1 on: June 06, 2010, 07:50:40 PM »
We are building the bumper out of 1/4" flat stock.  I had picked up a plasma cutter from Brink the spring and it is making the fabrication so much easier.
Dana and I ghetto'd a guide for the plasma so we could cut straight lines.
« Reply #2 on: June 06, 2010, 08:00:06 PM »
The main part of the bumper is now together. We had to cut out the tube at the front of the frame for the lights and for the tow hooks.  The metal for the hooks extends along the outside of each frame rail.  We did some fancy tubing set a bit farther back to replace what we cut out at the front of the frame and to support the front body mount.
Next is to fab up the housing on the each side for the LED lights and add the stinger/bull bar.  It's not a full stinger but it's not a little bull bar either.  Maybe a binger?
« Last Edit: June 06, 2010, 08:02:20 PM by specialk »
Offline slimbeam
« Reply #3 on: June 06, 2010, 08:34:23 PM »
looking good Kevin
« Reply #4 on: June 06, 2010, 08:51:54 PM »
Looks good...I like the design.
Offline Rich99
« Reply #5 on: June 06, 2010, 09:21:10 PM »
wow guys, that is awesome... you should have made a couple while you were at it. Are you planning on making any more?
Rich.
« Reply #6 on: June 06, 2010, 09:27:06 PM »
or is it a Bunger?
Offline Pookapotamus
« Reply #7 on: June 06, 2010, 09:31:59 PM »
wow it looks good now that its all welded and ground!
« Reply #8 on: June 06, 2010, 09:36:05 PM »
Nice craftmanship fellas... looking forward to seeing the rest of the built... keep on the good work!
« Reply #9 on: June 06, 2010, 10:45:44 PM »
Consider your design stolen, should look better than a new ARB.
Looks sick Kev, it better be done for the S&S.
« Reply #10 on: June 07, 2010, 07:41:01 AM »
Thanks - I'm pretty pumped about it.  And it will be ready for the S&S.
« Reply #11 on: June 07, 2010, 09:12:10 AM »
here is a 3d image of what it will look like, well before we changed it in fabrication.  8)
Offline apex
« Reply #12 on: June 07, 2010, 11:22:07 AM »
Would you share your .dwg files? I'd love to see how you built that in my CAD software. oa*vc@tel*us.net (delete the stars)
« Reply #13 on: June 07, 2010, 11:31:42 AM »
it was designed in inventor the only dwg files are the actual fabrication drawings but they are not my property to give away, you will have to ask kevin.
« Reply #14 on: June 07, 2010, 05:02:54 PM »
is it done yet i wanna see it on your jeep already
