Author Topic: YJ front end clunk  (Read 3485 times)
YJ front end clunk
« on: August 04, 2010, 09:29:12 PM »
just replaced unit bearings on jeep, the axle seal on the passenger side, and swapped in bigger ujoint axles.  the pass. side i stuck with the two piece shaft, and on the drivers i swapped in a bigger TJ axleshaft, with the ABS tonering on it.   now i went for a rip, and its clunking bad. but not while moving, under load, or anything, it only clunks when the suspension moves (like the bump at the end of the driveway) or i can replicate the sound by rocking the jeep back and forth.
any ideas before i rip the front end apart again?
unit bearings are new, ball joints feel tight, u joint in the axle is tight; there is no play in it.
the only thing i can think of is somehow maybe the tone ring his hitting something, or possibly the u joint is bad? it feels tight and there is no movement in it that i can feel. can it still be the culprit?
any ideas?
« Last Edit: August 04, 2010, 10:01:51 PM by JOhnnyC »
Offline esi
Re: YJ front end clunk
« Reply #1 on: August 05, 2010, 12:13:42 AM »
What did you torque your wheel nuts to? I've had to torque mine to 105ft/lbs to keep them from loosening
Formerly of Boots & Boost Inc
« Reply #2 on: August 05, 2010, 08:31:49 AM »
lugs on both the wheel spacer and the wheel are 'johnny' tight, which measures to about 100ft lbs.  theres no play at all in there.  looks tight, feels tight........ and makes horrible clunk/banging noise.
i'm gonna be ripping it apart after work again tonight :(
« Reply #3 on: August 05, 2010, 08:57:20 AM »
Have someone else listen closely while you're swaying it back and forth to find out exactly where noise is coming from before tearing it apart.
Could be just a finger tight bolt on something else up there.
« Reply #4 on: August 05, 2010, 09:01:50 AM »
have someone bounce on the bumper while you look around. It sounds suspension related from your description.
« Reply #5 on: August 05, 2010, 10:17:00 AM »
when i get home i'll do all of the above.
just irks me sitting behind a desk all day when i'd obviously rather be tinkering.
Offline Sean778
« Reply #6 on: August 05, 2010, 02:55:21 PM »
I know the feeling buddy. The internet really doesn't help either. :)
'89 XJ
Offline Knox
« Reply #7 on: August 05, 2010, 03:15:29 PM »
my work gave us all hacky sacs today...  I really don't know what they were thinking, productivity went wayy down :P
2003 TJ
« Reply #8 on: August 05, 2010, 09:17:59 PM »
YJ front end clunk ..... I ROCK!!!!
« Reply #9 on: August 05, 2010, 09:34:39 PM »
Bills right;  it was suspension related......... lets just leave it at that............
« Reply #10 on: August 05, 2010, 09:42:02 PM »
oh no you don't.... you NEED to elaborate, for all the inquiring minds that want to know.
Offline Sean778
« Reply #11 on: August 05, 2010, 09:45:11 PM »
Yeah buddy, I wanna know why Trev won. ;)
'89 XJ
« Reply #12 on: August 05, 2010, 09:52:12 PM »
sean, put a better pic of your heep up  ;D ;D ;) ;)
turns out the sound (we think) is/was in the leafs. rubbing or something along those lines.  jacked jeep up, soaked leafs in WD40, and its gone................ sooo weird.....
this was after i swapped out the front axleshaft ::)
thanks trev.....................................
« Reply #13 on: August 05, 2010, 09:54:09 PM »
you're welcome good sir.
Trevor 2
Johnny 0
« Reply #14 on: August 05, 2010, 10:06:31 PM »
That WD 40 wil evaporate pretty quick. The way I see it, you've only got two choices if you want to keep that clunk under control long term:
#1. Convert your YJ to coilovers.
#2. Remove all the WD-40 and apply belt dressing instead.
