Author Topic: pick and pull today  (Read 6754 times)
Offline .:.Dingman.:.
pick and pull today
« on: August 14, 2010, 11:44:31 AM »
10 zj, 5 xj and one five.niner
Dingman
Re: pick and pull today
« Reply #1 on: August 15, 2010, 10:25:56 AM »
What color was the 5.9?
Still intact?
« Reply #2 on: August 15, 2010, 01:16:40 PM »
white and for the most part yes I do believe it was missing its front header panel and lights.
Dingman
« Reply #3 on: August 15, 2010, 07:59:09 PM »
Well I hope whoever stripped that 5.9 before I got there is someone on here.....   :P
Offline CatSplat
« Reply #4 on: August 16, 2010, 12:16:25 AM »
Anything left on it? Was busy this weekend but I'll grab the rear end if it's still there.
Jeep of Theseus
« Reply #5 on: August 16, 2010, 12:21:35 AM »
I'll probably see you there in the AM. Better be fast ;D
Offline CatSplat
« Reply #6 on: August 16, 2010, 11:17:40 AM »
WTF, you already HAVE a D44a! I'm a working man, so there's no way I could get there this morning. :D
Jeep of Theseus
« Reply #7 on: August 16, 2010, 12:00:35 PM »
Was still there at 4pm on Sunday.
Offline CatSplat
« Reply #8 on: August 16, 2010, 07:35:18 PM »
Thanks for the heads-up cLAY, the Trac-Lok D44a is now out of the 5.9 and awaiting installation under my ZJ! It was a heroic one- man wrenching effort but I got it out with 5 minutes to spare before the place closed. :D
Sadly, the driveshaft was missing, so I'm on the hunt for one that's the correct length. I hear the 5.9 D44a used a larger u-joint than the 5.2 so it may take a little work to find the right shaft and joint.
« Last Edit: August 16, 2010, 08:25:59 PM by CatSplat »
Jeep of Theseus
« Reply #9 on: August 16, 2010, 10:06:07 PM »
how much did you pay for it if you dont' mind me asking????
also, are you gonna truss that puppy before instal?
« Reply #10 on: August 16, 2010, 10:39:58 PM »
Nice find Trev, I sent you a PM on the other site if you see this post first.
Offline CatSplat
« Reply #11 on: August 17, 2010, 12:15:29 AM »
Final bill with core charge ($15) and GST was $118.94. I do indeed plan to clean it up and truss it before it gets bolted in. Hopefully that'll happen before winter, haha!
BTW, you can look up PnP prices on their site, though front axles are listed under "axle" and rear axles are listed under "rear end" :D
http://www.picknpull.com/part_pricing.aspx?LocationID=76
Got your PM Fraser, shot you one back.
Jeep of Theseus
Offline Brooneg
« Reply #12 on: August 17, 2010, 11:29:53 AM »
Sorry newby question...what do you mean by "trussing" the D44?
Offline CatSplat
« Reply #13 on: August 17, 2010, 11:51:48 AM »
"Trussing" is when you weld a section of metal across the axle tubes to strengthen the unit via reducing tube flex under load. Here's a picture of an truss on the particular axle we were discussing.
Speaking of trusses, does anyone know what Jay generally charges for a truss job? I can get an MVC truss out of the States for $150 but I'd rather support a local guy if his prices are comparable.
« Last Edit: August 17, 2010, 11:54:41 AM by CatSplat »
Jeep of Theseus
« Reply #14 on: August 17, 2010, 11:59:32 AM »
better question is how are you gonna weld the aluminum centre section to the cast iron axle tubes?
not sure, but doesnt' the one in the U.S. bolt to the housing and then weld to the tubes?
just curious for when i FINALLY sell my dodge and get me a 5.9er ;)
