Author Topic: Inverted TORX on the top of the bell housing  (Read 2511 times)
Offline thevalleyboy
« on: August 29, 2010, 11:23:29 AM »
Does anyone know where I can getéborrow that damn inverted TORX socket that I need to the top of the bell housing in a 2001 TJ - kinda need to get this new clutch in there.
Thanks in advance for any info
2001 TJ Sport - Stock except for the 31's
Re: Inverted TORX on the top of the bell housing
« Reply #1 on: August 29, 2010, 11:28:10 AM »
princess auto has a set you can buy that has about 8 in the kit. pretty cheap too. i cant recall which it is but its in the set.
« Reply #2 on: August 29, 2010, 11:55:48 AM »
Part Source has the JET brand sockets you can buy individually, I got my 10mm there for the T case for $5 something. Let me see if I can find the size on the tranny for you.
« Reply #3 on: August 29, 2010, 12:03:18 PM »
It's an E12.
« Reply #4 on: August 29, 2010, 05:04:01 PM »
Princess auto. I don't know whose dumb idea that was but they should be made to go back and remove everyone of them. I usually replace them with regular hex heads when putting the tranny back in.
« Reply #5 on: August 29, 2010, 06:26:31 PM »
Meh you need the socket to get em out once, might as well reuse the factory one as you've now got the tool for it! haha.
« Reply #6 on: August 29, 2010, 10:42:27 PM »
That's assuming you're the next one to pull it out.....
« Reply #7 on: August 29, 2010, 11:35:27 PM »
Well if you're not pulling it, you don't need to worry!  ;)
While we are on the topic of replacing bolts, where do you get your bolts anyways?
« Reply #8 on: August 30, 2010, 10:11:30 AM »
bolt supply.
replace the bolts with hex ones.  i did when i did my clutch. was sure glad i did, because i was swapping engines a month later...........  torx = sux
