Author Topic: 2000 Jeep TJ with a 4.0L  (Read 4241 times)
Offline IgniteTJ
« on: December 30, 2010, 06:11:48 PM »
Hey there all, first post and all..
A few months ago I picked up a 2000 Jeep TJ with a 4.0L and want to build it into a 4x4.. My dad is a mechanic and the engine has a really bad knock and as such we need to replace it.. Now the lowest price I can get for a rebuilt is about $2700 all told.. We don't know the best economical way to go.. I don't really want to put a used engine back in since we are rebuilding everything else to new standards.. So the big question is whether to send it off to carstairs to get the engine that's in it currently rebuilt (256,000km on it) Get that same engine made into a stroker.. Order the rebuilt and just put that in and rebuild my 4.0L on the side.. Or just go big and put a chevy 350 under the hood..
So I'm basically looking for prices and costs if anyone has gone the sending the engine in to make it a stroker route.. Or putting a 350 under the hood..
Thanks!
Re: 2000 Jeep TJ with a 4.0L
« Reply #1 on: December 30, 2010, 06:30:28 PM »
cummins
thats the route ill be  going
Offline IgniteTJ
« Reply #2 on: December 30, 2010, 06:34:50 PM »
Haha my next truck will have a cummins in it.. But not too sure I want to put an engine that heavy into my TJ
Offline esi
« Reply #3 on: December 30, 2010, 07:13:44 PM »
My brother has a 327 that was rebuilt, ran in a engine stand for maybe an hour then put in a shed. Its sat for about 10 years in a shed so it might need a tear down and little clean up, but if your interested I could ask him how much he would want for it. If you're thinking of the V8 option. I believe it was 400+ horsepower and should have been about a 6K redline.
But you'll need a tranny and rad too.
Formerly of Boots & Boost Inc
Offline IgniteTJ
« Reply #4 on: December 30, 2010, 07:17:19 PM »
I'll ask my dad on that one and get back to you, having to find a new rad and tranny may be an issue though - the one thats in there is already rebuilt.. Thanks though =)
« Reply #5 on: December 30, 2010, 08:10:26 PM »
cummins made a 4 banger
4bt search it . theres lots of info on it and it only weights 700 LBS so not to much more then your stock 4.0
« Reply #6 on: December 30, 2010, 08:22:21 PM »
the jeep was designed for the motor it has in it now.  even a stroker can tear apart the rest of the stock drivetrain if you aren't easy on the pedal.  the motor it has in it now is plenty powerful enough to move the brick in stock form without any issues.
$2700 sounds high to me but would be my only choice of the ones you posted above.
Offline IgniteTJ
« Reply #7 on: December 30, 2010, 09:06:20 PM »
That price is from renfrew chrysler on an account so already quite a bit knocked off because of preferred customer.. The other one they list is $4000.. But the $2700 one comes with a new oil pan, new timing cover and a 80,000km warranty on it.. I'd prefer to stay stock like you said since the jeep is built around the stock motor
« Reply #8 on: December 30, 2010, 09:15:17 PM »
Offline IgniteTJ
« Reply #9 on: December 30, 2010, 09:17:13 PM »
lol isn't that just wonderful
« Reply #10 on: December 31, 2010, 09:56:22 AM »
Check with the american stroker sites. You can get an affordable short block strocker from them for reasonable dollars.
Offline IgniteTJ
« Reply #11 on: December 31, 2010, 11:48:27 AM »
Thanks I'll check them out :) sounds more and more like I'm getting the one from renfrew though
« Reply #12 on: January 02, 2011, 12:40:41 PM »
Personally I would find a low milage used motor and freshen it up, new seals, maybe new rings and bearings if you feel really ambitious. The 4.0L is a pretty stout engine and commonly go 300,000kms with basic maintenance. Even a used motor with 150,000kms would give long life with a freshening up. The money you save can be used to buy some goodies like maybe a cam and header. I've rebuilt motors before and find that for the cost a low milage unit is WAY cheaper and just as good. I can usually buy a complete wrecked vehicle with a good motor for about 1/2 to a 1/3rd of what a rebuilt will cost.
Thats just me though, if you've got a generous budget and want a simpler route then a factory rebuilt maybe the ticket.
Offline Possum
« Reply #13 on: January 10, 2011, 08:30:27 AM »
Just ordered all to parts for a stroker build in my zj.  As was stated it's not going to be cheap, but if you need an extra 100 ft-lbs then its an easier route than a V8 swap and a lot easier than a diesel swap.  I looked into several options before deciding to build one.
option 1: Precise engine rebuilders in Calgary have a 4.6L shortblock for sale for $2000, but I think they'd take less.  Apparently, a customer ordered it and couldn't pay for it.  In the end, it wasn't exactly what I wanted so decided not to.  Also, their customer service is questionable.
option2: order a prebuilt long block from golen or Hesco out of the states.  Stay away from Titan.  They are the cheapest, but lots of guys have had trouble with their engines and spend more in the end.  Hesco is rated as the best, but $1000 more than golen.  Golen has a realy good rep.  I would go with them.
option 3:  do a ton of research and figure out what you want.  follow a proven recipe and go for it.  This is the recipe I chose:
   http://telusplanet.net/public/cdkruchk/Stroker%20Recipe%202009.pdf
   I'm getting firebolt to do the machining and assembly.  In the end I expect it to be in the $3000 range.
There are also a ton of info available on jeepstrokers.com
Offline esi
« Reply #14 on: January 13, 2011, 08:44:06 PM »
? A V-8 swap for a ZJ seems pretty simple, sell I-6, find a Limited, swap done ;)
