Author Topic: Wiper Blade Arms not sitting flush  (Read 10486 times)
Offline FirstTimer
  • Gettin there!
« on: January 18, 2011, 11:50:55 AM »
With the weather getting nice again, having wiper blades that work properly is a must!  My jeep doesn't seem to agree with this!  I thought I had fixed the issue with my wiper blades not sitting flat agains my windsheild by making a few small bends in the arm, but the cold snap we just had must have undone all my work.  Is there a bolt or nut that can be tighted on the wiper blade arm that will make it sit tighter to the windsheild? Or am I going to have to suck it up and pay to replace it?
Thanks!
Re: Wiper Blade Arms not sitting flush
« Reply #1 on: January 18, 2011, 12:41:37 PM »
You can adjust it by taking a large hammer and beating on it.
or just buy a new one.  That may work too  ::)
Offline Knox
« Reply #2 on: January 18, 2011, 12:54:31 PM »
unless I drempt it up, you can buy springs somewhere and they make the wipers sit tighter.
2003 TJ
« Reply #3 on: January 18, 2011, 12:56:20 PM »
Persuading additional curves into the lustrous chemical element has little impact applying pressure to the window.
They're engineered with a recoil device to achieve this application of force.. Do you have a recoil device? Is your recoil device worn out? Is it installed correctly?
If your swipers not swiping,  see if it looks like this,
« Last Edit: January 18, 2011, 01:09:06 PM by frenchy »
« Reply #4 on: January 18, 2011, 01:18:30 PM »
There's a spring underneath the wiper arm that you can modify to make your wipers  work better. Drill a new hole and move the spring so that there is more tension on the blade/arm.
Offline FirstTimer
  • Gettin there!
« Reply #5 on: January 18, 2011, 04:59:46 PM »
See I figured bending it would provide a greater angel and therefore more pressure... but i was never good at math nor do I have much mechanical knowledge!  This would explain why it didn't work.  I'll have a look at the spring and see what I can do.
Good luck to me
« Reply #6 on: January 18, 2011, 05:46:48 PM »
clean and lube the pivot.
Offline Tinkerer
    • My (OLD OLD OLD) website
« Reply #7 on: January 18, 2011, 08:37:21 PM »
I second this one. Mine need to be lubricated regularly as they seem to have some bimetal corrosion there and stiffen up. I used to have supplementary springs until they snapped, but that simply delayed the problem, though it did extend the lubrication intervals :)  When the weather is nicer, I think I'll take mine off and soak them overnight.
I didn't notice this on the maintenance schedule!  ;D
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
Offline Alltornup
« Reply #8 on: January 18, 2011, 10:23:19 PM »
My Jeep have never had a problem.  But the Girlfriends TJ is same as yours.  Took a good 2-3 weeks of lube to get it back to wiping clean.
Offline FirstTimer
  • Gettin there!
« Reply #9 on: January 19, 2011, 10:33:14 AM »
I haven't taken a good look at the pivot yet, but it seems bending the arm back away from the windsheild seems to put better pressure on the wiper blades.  Although I have been getting a squilling noise when I use them for the first time everyday.  This may be a lube issue or a motor issue?  It sounds like a pig squilling!!!
I've I were to lube the pivot is there anything besides common sense that I should know?
Offline Tinkerer
« Reply #10 on: January 19, 2011, 10:05:37 PM »
I was told the squealing was normal when it's cold out, so I haven't tried doing anything about it.
Offline FirstTimer
  • Gettin there!
« Reply #11 on: January 19, 2011, 10:55:41 PM »
Well that sucks if the squilling is normal...nothings more annoying than that noise when youre barely awake in the a.m.
Offline The Machinist
  • I’m with stupid!
« Reply #12 on: January 20, 2011, 06:34:51 AM »
A little belt dressing should fix that squilling!
« Reply #13 on: January 20, 2011, 07:15:05 AM »
Make sure you use the kind with extra zinc.
Offline FirstTimer
  • Gettin there!
« Reply #14 on: January 20, 2011, 10:04:32 AM »
Where do I pick up this "belt dressing" you speak of? Canadian tire?
