Author Topic: Wiper Blade Arms not sitting flush  (Read 10484 times)
Re: Wiper Blade Arms not sitting flush
« Reply #15 on: January 20, 2011, 10:20:32 AM »
spray it with Wd 40.
when it starts squeeking again, spray it with WD40
« Reply #16 on: January 20, 2011, 10:27:11 AM »
Where do I pick up this "belt dressing" you speak of? Canadian tire?
Same place you get muffler bearings
Offline FirstTimer
  • Gettin there!
« Reply #17 on: January 20, 2011, 10:49:57 AM »
NOT HELPFULL!!!  :-\
WD40 IT IS! Maybe I could use some to lubircate Tubby's attitude as well!
« Reply #18 on: January 20, 2011, 10:53:15 AM »
They are pulling your chain, buddy...
« Reply #19 on: January 20, 2011, 11:05:20 AM »
NOT HELPFULL!!!  :-\
Are you an adult?
Are you looking to be spoon fed?
Me and several others have given you ideas on how to fix your simple problem. It's not rocket science.
Are you going to jump into fourwheeling armed with only a modicum of knowledge on how your TJ works?
Are you going to expect others to help you when something breaks on your Jeep or stand and watch helplessly?
I'm not being mean kid. I talked Eric into greenlighting you for this weekends run and I've also pm'ed you in the past offering you help with your Jeep.
Offline FirstTimer
  • Gettin there!
« Reply #20 on: January 20, 2011, 11:46:09 AM »
I am most certainly an adult!  The first thing I learned as an adult was to seek out advice from those that have more wisdom and knowledge of things that you do not, so you don't whined up screwing yourself over! I would rather get some simple info of how to fix my problem before screwing around with a piece of equipment that could cost me 300$ to replace.  I could also spend hours of my time searching out info on the web (that may not be accurate) or I could ask the guys on this forum that I have come to trust a great deal.  So spoon feed NO, but resourceful YES!
Additionally, I will be the first to admit that I ask simple questions, which require simple answers.  I am here to increase my very limited knowledge of Jeeps (auto mechanics in general) and if you are going to take the time to answer my questions, then why not just answer them!  I have no intention of being the guy on the runs that is helpless when problems or breakages occur or the guy that takes his Jeep into the shop to be fixed everytime! Hell I was proud of myself for mounting and balancing my own tires/wheels and for changing my headlights!  That being said if you feel like I need to keep these types of questions to myself and search out the answers myself then I can do that.  But I was under the impression that this was an open forum where guys like me could learn!!!
Finally, Tubby I did not mean to offend you!  I apologize if I crossed a line with my comment. I thought that you and I a bit of a repour due to our previous conversations and I was just being playful...
« Reply #21 on: January 20, 2011, 11:51:05 AM »
No worries guy. I hope you have your wiper issue fixed soon and have fun this weekend at the Hot-Chocolate run.
Offline FirstTimer
  • Gettin there!
« Reply #22 on: January 20, 2011, 11:52:55 AM »
Thanks dude!
I appreciate you putting in the good word for me!   ;D
You going to be there?
Offline Knox
« Reply #23 on: January 20, 2011, 01:17:07 PM »
It's a Trap!
also my wipers squeal when cold, is it wrong when my wife asked if I need anything at Canadian tire this morning I said belt dressing for my wiper assembly?
2003 TJ
Offline FirstTimer
  • Gettin there!
« Reply #24 on: January 20, 2011, 01:35:55 PM »
It's a Trap!
No trap here! I'm not a guy to hold a grudge  :)
Knox do you apply the belt dressing on the wiper blade motor or on the hinges that come out of the hood?
Offline The Machinist
  • I’m with stupid!
« Reply #25 on: January 20, 2011, 02:51:34 PM »
You have been the victim of an inside joke and I apologize for having a laugh at your expense.  To clear things up, belt dressing is for belts.  Do not spray it on your wiper motor, do not spray it on your hinge or spring, do not buy it.
Offline FirstTimer
  • Gettin there!
« Reply #26 on: January 20, 2011, 03:08:06 PM »
I was curious about the name... thought it was one of those things that had an original use, but became multi-purpose...  :-\
Looks like I need to start asking more serious questions on here to avoid this happening again!
Offline scott slade
  • Amboy... Route 66
« Reply #27 on: January 20, 2011, 04:55:42 PM »
Thank God  you didn"t ask about improving your gas mileage...!!!!!   lol   8)
2005 LJ, Six Speed,
 16" Moab Rims
Offline Hi Lo Silver
« Reply #28 on: January 20, 2011, 07:59:46 PM »
First timer, the best hundred or so dollars you'll ever spend on each vehicle you ever buy and own is to order the proper shop manual (not owners manual). Don't get Chilton or Hanyes (proper name optional), but get the specific manual from your jeep dealer or through the mail.
Internet can be brutal sometimes. Shop manual is well worth it in so many ways.
Offline FirstTimer
  • Gettin there!
« Reply #29 on: January 21, 2011, 09:20:23 AM »
Hi Low,
Thats some of the best advice I've been given!
