Author Topic: id these axles  (Read 2394 times)
Offline .:.Dingman.:.
id these axles
« on: February 09, 2011, 09:49:13 PM »
the ad says they're dana 44 but I have my doubts. can anybody id them.
http://alberta.kijiji.ca/c-cars-vehicles-auto-parts-tires-transmission-drive-train-3-4-Ton-4x4-Diffs-W0QQAdIdZ216810931
thanks
Dingman
Re: id these axles
« Reply #1 on: February 09, 2011, 11:01:50 PM »
camper special was a chevy or ford name for heavy duty back in the day. so the front would be d44, the rear would be d60(ford) 14bolt(chev). the front 44 being 3/4ton would be the beavy duty version, thus the bigger 8 lug hubs/knuckles. 400$ isnt bad if they are in decent shape. with those gears you could add lock-rites and go wheeling. id get more info from the seller.
Re: id these axles
« Reply #2 on: February 09, 2011, 11:03:25 PM »
Thank you hps put a beer on my tab.
Just have to figure out how to transport/store all my eagle and zj parts.
Dingman
Re: id these axles
« Reply #3 on: February 09, 2011, 11:32:43 PM »
Chevy made 2 14bolt axles over the years, one being a 9.5" ring gear, which is what that looks like, and also a 10.5". The 10.5s were used under 1973-87 3/4-tons, and are easily converted to run disc brakes with a caliper bracket that Modern Motors even has in stock. (I had mine converted and it works great!)
The 9.5" ring gear models used in the rear of 1964-and-later GM pickups, and in the rear of 1984-91 3/4-ton Suburbans. This one looks more to me like a 9.5" version. The bigger 10.5 ones have a very unmistakable shape to them being a lot more angled. This one seems a bit rounder. I'm not sure if they are a full floating axle or not, but the 10.5 definitely is.
9.5"
10.5"
Re: id these axles
« Reply #4 on: February 09, 2011, 11:41:14 PM »
tliguana
thanks for your help the 9.5's are semi floating and the 10.5's are full floating.
Dingman
Offline Mudhawg
  • Rig Life
Re: id these axles
« Reply #5 on: February 10, 2011, 12:53:30 AM »
looks like a semi float 14 bolt and either a 44 or 10 bolt front good setup my buddy runs 37 boggers on a SF 14 and hasnt had any issues
