Author Topic: What did you do to your Rig Today  (Read 12228 times)
Offline silverfox
  • drawrof og nac enoyna
« on: February 14, 2011, 10:08:38 AM »
I was reading through the old thread like this one and thought it was interesting and seemed to have some traction so I figured what the hell I would start a new on (the old one is over 2 years old)
I straightened out my left front adjustable sway bar link..............it was a little bendy new ones on the way this week.
Re-centered my steering - same issue that caused the above caused a little steering movement
Re-Seated my right front coil spring, it had jumped out of the seating channel in the bottom.
I think Rubi was a bit mad at me............she bit me when I was pulling the sway link out.
Finally installed my daystar hood latches........man are they tight no more hood flutter for sure.
Soooooo what did you do to your rig today.
2018 JLU Lifted on 37's
Re: What did you do to your Rig Today
« Reply #1 on: February 14, 2011, 10:41:05 AM »
sold it  ;D
and bought a car  :o
Offline AstraX
« Reply #2 on: February 14, 2011, 10:44:26 AM »
Nothing today, but yesterday I got the compressor install finished so it works now and went down to see Simon to try and figure out my CB issue...it just started working all of a sudden so that's fixed too.
Offline scott slade
  • Amboy... Route 66
« Reply #3 on: February 14, 2011, 10:47:01 AM »
Gathering parts for the big trip back to the Mojave in April.   Picked up the CB antenna bracket and windshield light brackets.  Installed new headlights to take H4 bulbs.  Still looking for soft top roll bar brackets and rear retainer bar.   Give me a few more days of warm weather to get it done....... 8)
2005 LJ, Six Speed,
 16" Moab Rims
« Reply #4 on: February 14, 2011, 10:47:39 AM »
I drove mine to work today... But tomorrow, I will likely put her up on stands, rotate the rubber, and install a couple of new skid plates!
Thanks for the new toys Waytec! ;)
Offline Jrama
« Reply #5 on: February 14, 2011, 11:22:21 AM »
Yesterday i changed out my hub units for the second time in a 6 monthish period. There was just over an inch of play maybe a little more  on the driverside :o. Auto value honoured the warrenty on the crappy BCA bearings. After doing this, the jeep braked better and was significantly less noisey.
 Today, I took it to the dealer for the engine tick, they declared it alittle noisey but not enough. It certainly ticks  but my warrenty is good till 2012 so they just told me to keep an ear on it. Jeep has an exhasut leak from a stray log that may contribute to noise so..... no resolution as far as I am concerned. Plus for engine warrenty they need proof of oil changes, thats kind of hard when you do them yourself...I think i got most of my reciepts though.
« Last Edit: February 14, 2011, 11:27:12 AM by Jrama »
Offline murray195
  • No such thing as secrets... just useful info
« Reply #6 on: February 14, 2011, 11:35:02 AM »
Installed seats out of a Mitsubishi 3000GT... adjustable lumbar support, tilt... much better than unadjustable springy factory yj seats  ;D
Offline silverfox
« Reply #7 on: February 16, 2011, 07:17:50 AM »
Adjusted my steering center............again (think I have it this time)
Given that the warm weather is gone for a bit, I washed about 100lbs of road silt off of it.
Offline cuzican
« Reply #8 on: February 16, 2011, 12:36:05 PM »
Last night I prepped and painted my Metalcloak fenders and flares.
Tonight they should get the final coats.
« Reply #9 on: February 16, 2011, 12:49:32 PM »
Cleaned the snow off it and decided it was too $#^%ing cold to swap the fog light wire harness in.
Offline BlackAura
  • 2003 TJ Rubicon (Stock)
« Reply #10 on: February 16, 2011, 01:56:56 PM »
Fixed the roof rack so it doesn't rattle.
....almost time to rotate the tires though, thanks for reminding me Simon!
BlackAura (Kevin)
« Reply #11 on: February 16, 2011, 05:02:21 PM »
Quote from: BlackAura link=topic=21423.msg130808#msg130808 date=1297889816
[/quote
never did get around to mine, so if your bored your more than welcome to do the xj's as well! ;)
Offline 88xj
« Reply #12 on: February 16, 2011, 08:59:20 PM »
had to weld my homebrew bar pin deletes in and put longer rear shocks
Offline mtngoat
« Reply #13 on: February 16, 2011, 09:20:11 PM »
I bought some new mirrors and headlights. Hopefully install them this weekend.
Offline dubbleJs
« Reply #14 on: February 17, 2011, 02:31:09 AM »
Rebuilt the driveshafts...now that annoying wobble should be gone!
