Author Topic: What did you do to your Rig Today  (Read 12248 times)
Offline xjpete
  • New ride
Re: What did you do to your Rig Today
« Reply #15 on: February 17, 2011, 08:14:39 PM »
rebuilt a holley 650 mecanical sec  and drew up a anti wrap for the rear .
97 XJ,8'' LA ,35's , SBC .
98 ZJ daily driver .
Offline ornamental
« Reply #16 on: February 17, 2011, 09:53:22 PM »
i found another leak in the rad  :(
Offline silverfox
  • drawrof og nac enoyna
« Reply #17 on: February 20, 2011, 01:23:02 AM »
Moved it out of the garage so I could fix the flat on the Expedition  >:(
2018 JLU Lifted on 37's
Offline Alltornup
« Reply #18 on: February 20, 2011, 02:28:36 AM »
Bougt 12 litres of mobile 1 and 2 wix filters and came home and then though it was way to cold to change oil on the girlfriends and my TJ.  Screw it, maybe after the Daytona 500 I will think about it.   And screw all ya with heated garages.
Offline Waytec
  • not all there
« Reply #19 on: February 20, 2011, 09:30:28 AM »
Yesterday - clutch on new engine back in, mounts torqued, t-case back on, working my from the back forward hooking stuff up,
this morning wash out rad at car wash they are really going to like me, hopefully have it running today
The obstacle is the path.
Offline FirstTimer
  • Gettin there!
« Reply #20 on: February 21, 2011, 12:37:15 PM »
I installed a CB radio!  My first "modification" and I think it looks pretty awesome and I can't wait to see how she works out on the trail.
HUGE thanks to Justin from Nine Industries for donating his time, tools and knowledge to help me get this done.   We were able to get the CB installed with little to no difficulty.  The only issue we ran into was ditaching the sub-woofer wiring harness and wires from the center console so we could take it out to install the radio.
Offline FirstTimer
  • Gettin there!
« Reply #21 on: February 21, 2011, 12:44:55 PM »
lets try this again...
We wired the CB to a "piggy back fuse" and used to sub-woofer port so that even when the vehicle is off the CB still gets power. Simple, clean and out of the way.
I wanted the Cb to be in an area that was easily accessable but also somewhat hidden, so behind the centre console seemed like the best spot.
For now the cup-holder will serve as my handset holder until I can get a mount for it as well as decide where I want it to be mounted.
Thanks again to Justin, he really knew what he was doing and we had a great time working on this together.
« Reply #22 on: February 21, 2011, 08:17:58 PM »
Why wouldn't you just wire it to your battery, instead of a piggyback fuse?
Offline AV.NINE
« Reply #23 on: February 21, 2011, 08:48:36 PM »
To be honest, WAY less work. Ive always run my cb's in that fashion. My theory is I need to talk to the guys ahead of me and behind me in a trail ride. I have never noticed excess "noise" from that location nor does it cut back on the range.
I am NOT a wiring guy. And I dont pretend to be. I've installed fog lights, cb's, tail lights, etc. But hey if it works, why knock it?
Heck Im still running my light forces to my stock fog light wiring lol
One day I'll upgrade.
Actually I forgot Kyle, I have an adhesive mic mount you can have. Remind me on Thursday and we'll put it on.
« Last Edit: February 21, 2011, 08:50:08 PM by AV.NINE »
« Reply #24 on: February 21, 2011, 08:53:21 PM »
Looks good Kyle.
Mounted up my front skid and got a compressor. Not a fancy schmancy ARB but it does the trick in good time and I have lifetime no questions warranty on it.
Offline silverfox
« Reply #25 on: February 21, 2011, 09:00:25 PM »
I took the Rubi to the car wash and got some of the grime off of her................oh and a ton of icy snow off the bottom
Offline FirstTimer
  • Gettin there!
« Reply #26 on: February 22, 2011, 10:03:50 AM »
Great Thanks Justin!
I look forward to getting the HI-JACK mount installed! I'll post up pics once its all put in.
Offline .:.Dingman.:.
« Reply #27 on: February 22, 2011, 10:12:20 AM »
Parked it in the garage wishing I could turn wrenches.
Dingman
Offline esi
« Reply #28 on: February 22, 2011, 10:33:26 PM »
Changed the rear diff oil in my 93.
found this
Said some four letter poetry
Not sure if the bolt holding the pin sheared or the pin broke out.
Then swapped the whole diff out with a spare that I had.
Formerly of Boots & Boost Inc
Offline Domengus
« Reply #29 on: February 26, 2011, 04:13:29 PM »
Hi everyone, I'm new to jeeping, i use to quad a lot but now i own a 2000 jeep Cherokee. A buddy of mine mentioned giving it a lift kit but said to do it cheaply you can use hockey pucks. Is this actually possible and if so would you think its a good idea.
Take me on your buggy take ta take me on your buggy, they be like dan, what, can you take me on your buggy, you know why cause everyone loves muddin',  and all I need is a lady to come up to me and you you and you be ready for some muddin'
