Author Topic: Ford Taurus electric fan owners  (Read 5972 times)
« on: March 26, 2006, 07:40:09 AM »
I was at Princess Auto in Calgary yesterday and they have a bin full of what appears to be brand new two speed Taurus fan motors. There was no price but I imagine they are cheaper than anywhere else. They are located in an aisle near the back of the store along with the other misc. auto electrical junk like wiper motors, fuse boxes etc.
I'm 99% certain they are the exact same as the motor I had on my old setup, it even has the Seimens label on it.
Vince
Offline midnightcowboy
« Reply #1 on: March 26, 2006, 06:44:31 PM »
can anyone confirm?
« Reply #2 on: March 27, 2006, 12:26:01 AM »
doh!, I was just there and missed them. Didnt have that on my mind though.
Thanks Vince, I'll be heading over tommorrow to check them out.
« Reply #3 on: March 27, 2006, 05:47:44 PM »
Thanks Vince.
Picked up the last 4. Not sure when I'd gettem for 19$ again so grabbed a few :D .
Only difference is the end plug which will be an easy splice.
« Reply #4 on: March 27, 2006, 06:32:48 PM »
Quote from: "bnine"
Thanks Vince.
Good job Bill, you got 4 for about half of what I paid for 1 new fan.
Vince
« Reply #5 on: March 27, 2006, 09:39:53 PM »
Quote from: "Vinman"
Quote from: "bnine"
Thanks Vince.
Vince
No kiddin. And since we are switching Denise's over right away, I figured a spare or two at that price wasnt a bad idea.
Got a good place to recommend getting the controller from? I grabbed a shroud and fan out of a taurus at pnp for her tonight.
« Reply #6 on: March 28, 2006, 06:42:27 AM »
Quote from: "bnine"
Quote from: "bnine"
Thanks Vince.
Vince
The controller I sold you came from Mopac, I believe it was about 80 bucks. They also have the same controller with a sensor that fits between the cooling fins of the rad or inserted between the rad hose and rad.
Vince
« Reply #7 on: March 28, 2006, 08:24:28 AM »
Awsome, thanks Vince.
Wif
« Reply #8 on: March 29, 2006, 12:04:00 PM »
Does anyone know if these are still at PA .. and if so, how much are they ?
« Reply #9 on: March 29, 2006, 05:36:59 PM »
Quote from: "88Jeepster"
Quote from: "Bnine"
Picked up the last 4. Not sure when I'd gettem for 19$ again so grabbed a few.
Offline RckyMtnTJ
    • http://www3.telus.net/lck
« Reply #10 on: March 29, 2006, 06:18:03 PM »
I scoured the Lethbridge store.  However they didn't carry them. :(
98 TJ 4" lift + goodies
HIWYH8R
« Reply #11 on: March 29, 2006, 09:10:47 PM »
I used a thermostat controller from Mopac that goes inside your rad hose for 35 bucks. Just a cheapy but works fine. One trick I learned is to install the coolant probe in the bottom rad hose. The reason this is better than the top hose is that the fan will only run when is needs to which is hardly ever in my 4 cyl.  If you intall the probe in the top hose then the fan is running more cause that is the temp Leaving the engine (hotter). In the bottom hose the probe is sensing the temp going Into the engine which takes into consideration your speed (airflow) through the rad and how hard your driving at low speed.. hope that makes sence.
My fan never turns on while city and most off road driving. Also I set my fan to come on 10-15 degrees above my actuall 190 degree thermostat so that it is always open and my fan and/or driving speed regulate engine temp. Works great.
The only pain in the A$$ is getting the little tube for the probe to seal in where it goes into the rad hose. They give you a little gromet type thing but it's a pain to install and keep from leaking. Hose clamp needs to be very tight.
« Reply #12 on: June 20, 2006, 06:46:15 AM »
I was at Princess Auto on the weekend, they have another 4 or 5 of these 2 speed fan motors in stock for 20 bucks each, brand new.
Offline JohnB
« Reply #13 on: July 14, 2006, 08:46:34 PM »
Was there today.  2 left on the shelf.  1 in my hand.  :D
Offline BUKI
  • Project Fugly
« Reply #14 on: July 14, 2006, 10:07:54 PM »
I am new to this Jeep Thing.  So excuse the stupid question, but why does everyone want these Taurus fan motors.
I am very confused dont we drive chryslers
