Author Topic: "Blasphemy" Version 3.2  (Read 9841 times)
Offline JENSSEN
    • Racing For The Cure
« on: June 07, 2011, 01:07:39 AM »
The goal in4 weeks is  to do :
-weld on beadlocks (ordered)
-cage reinforcement
-linked and coiled rear
-tranny pan repair
-exhaust repair
-http://browndogindustries.com motor mounts (ordered)
-maybe bigger tires
-u joint repair, batt relocation
-maybe a new winch (Kingone)
-Front diff skid plate
Who knows if I will get it all done but I am entered in the 2011 www.highriders.ca challenge and I want to come out with my Jeep in one piece. I will be calling in friends and favors on this one,...
Previous years photos,..
http://video.icq.com/video/video_selected.php?vid=y6hKsIO-Efw&icid=vr_rmpn
www.racingforthecure.ca
Offline JENSSEN
Re: "Blasphemy" Version 3.2
« Reply #1 on: June 07, 2011, 01:09:10 AM »
Well the Chaos is about to begin,.. Blasphemy is finally in the shop!
Set the tail on the "stand"
going to be test fitting, XJ, TJ and what ever coils I can get my hands on to start the coil conversion,..
But during the week I got side tracked and did a 4" Iron Rock lift on the Wifey's Rubicon. My '93 XJ donated its rubber until I can get Her at least 33's under it. My XJ's cool factor has dropped 3-5 points since loosing its Rubi Wheels.
Offline JENSSEN
« Reply #2 on: June 07, 2011, 01:12:01 AM »
so Far I have wedged in some TJ stock front coils, but also have XJ stock and approx 2" coils as well,.. tell me more about these chev coils,...
Oh and the first of the rebuild parts arrived,.. Weld on outer beadlocks and inner bead stiffeners from SUREWAY Metals in Calgary Alberta.
Well I am not sure if you may or may not know this but if you plan on hard wheeling a Jeep with a 4.0you run the risk of sheering the bosses off the block like I did,...
To fix the issue at hand I purchase www.browndogindustries.com motor mounts.
First off, let Me say their customer service and knowledge of the 4.0 and Jeeps in general is amazing only trumped by their passion and the product they produce!
The mounts are VERY beefy, beautiful welds and a nice yellow powdercoat (I assume)
The hardware comes well packaged and easily identifiable and the instructions are very detailed
and obviously shows pride in the workmanship when they sign their product!
The install was very easy and took about 2 hrs to install with hand tools in my garage. I undid the motor mounts on both sides to the chassis and jacked up the motor enough to clear the frame mounts. Then removed the passenger side block plate. EASY! the only issue that slowed me down was one bolt that broke that took a bit to extricate.
and in,..
Fit like a glove!!
Now onto the passenger side :)
It went just as smoothly and actually faster over the driver side , the mount was a bit tight on the alternator but with some finesse on the alt mount it slid in.
Overall I love the product and it puts me one step closer to being ready for racing at www.highriders.ca Challenge . The cost is minimal for the amount of time that it would of taken to make them myself!
Just need to torque them all down and move onto the next project!
Offline Knox
« Reply #3 on: June 07, 2011, 08:15:13 PM »
I've been reading really good reviews of everything to do with the brown dog motor mounts, good to hear you were pleased as well.
Regarding Sureway, I've been talking to them a bit lately for work stuff (got a tour of one of their shops the other week, 120' long laser bed... and a 24' long break that can put a 90 in 3" plate... drool)
So the weld on bead locks, did you give them a file and they cut them out for you or do they already have that kind of thing in their  "Catalog"?
2003 TJ
Offline LEMON-AID JAY
  • Bad a$$ zj owner
« Reply #4 on: June 07, 2011, 08:53:45 PM »
-FOR SURE a new KINGONE winch
FIXED  ;D
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Offline JENSSEN
« Reply #5 on: June 07, 2011, 11:07:22 PM »
Start of the 4 link,.. Glenn helped me tonight and on 2.5 hrs we began,...
Stock XJ coil buckets:
Yes I am that "frugal" to reuse them,.. Freecycle anyone? :out:
Plasma'd that stuff down to size,..
Cut some brackets to "mock" up the stock XJ front buckets
I need to tack them in and test the ride height, then start the 4 link :)
Offline JENSSEN
« Reply #6 on: June 07, 2011, 11:08:36 PM »
Vance Whipped the drawing up in about 25 mins,... call Sureway ask for Vance
Offline JENSSEN
« Reply #7 on: June 07, 2011, 11:11:30 PM »
FIXED  ;D
Sweet!!!!!!!!!!!!
The warn took my battery to DOA a few times over a few years at HRC , after the pulls I saw on line and in person I hope ( I won't have to use it) but if I do it spanks the warn. It has killed my battery too many times in a spot of need!!!!!
Offline JENSSEN
« Reply #8 on: June 11, 2011, 02:08:02 PM »
OK well today Stephanie reminded me the competition is 22 days away,..I guess I better get started on the 4 Link rear,...
Well my jay at Chanda had these kicking around on the shop floor so I figured they would be a good start,..
and plasma!
make some diff tube mounts
Quick test fit
made some upper mounts from shop scraps
and some uni-body reinforcements to share the load of the coils, the goal os to locate them right below the rear cage tie ins :)
Chassis cleaned up
been going for 2 hours solid , so time for a quick break!
Offline JENSSEN
« Reply #9 on: June 11, 2011, 05:59:00 PM »
A few more hours a bit more progress,...
Went to sit it on the TJ coils and the leafs got in the way so I cut the old tabs off:)
Full weight on the TJ spring only, leafs are there for alignment only
Offline JENSSEN
« Reply #10 on: June 12, 2011, 04:42:32 PM »
Well more repairs today,...
Exhaust and tranny pan met a few rocks last year,...
New one with a splash of paint
and in
My poor pacesetter header,..
Had to chop a section out :(
Got to keep plugging away 21 days to race day
Offline JENSSEN
« Reply #11 on: June 14, 2011, 09:28:38 AM »
Got a bit more done after work yesterday,..
Burned in the outer locks, need to make a pass on the inside edge now
Next the inner bead stiffeners
Offline JENSSEN
« Reply #12 on: June 16, 2011, 11:48:39 PM »
Offline JENSSEN
« Reply #13 on: June 20, 2011, 11:23:41 PM »
working on the 4 link,.. scrapped a few ideas so far,.. a few templates
A few fabbed parts
don't know if I will use them
Notes,..
Masking tape 4 link,..
« Reply #14 on: June 20, 2011, 11:55:12 PM »
seems like your on track for your build .. good luck and see you out there at highriders
