Author Topic: I know another zj death wobble thread  (Read 2125 times)
Offline .:.Dingman.:.
« on: June 15, 2011, 06:35:07 AM »
95 zj 5.5 lift 33 tires
First off I've replaced:
Ball joints
Tie rod ends
Wheel bearings
LCA
Track bars
Steering stabilizer
Got an alignment and tires balanced caster is out
Besides bad uca, bad caster what else could be causing this.
Dingman from my iPhone
Offline mike s
  • Good times!
Re: I know another zj death wobble thread
« Reply #1 on: June 15, 2011, 07:36:13 AM »
shopping carts have bad caster too...
better off road, worse on  road.
oldEnuff2NObetter
but still can't help myself
Offline JENSSEN
    • Racing For The Cure
« Reply #2 on: June 15, 2011, 07:49:02 AM »
Chck the upper and lower maonts on the unibody for oblong holes where the control arms bolt in, also wheel bearing nice and tight and new? Have you checked balance on the beadlock sealer rime combo?
www.racingforthecure.ca
« Reply #3 on: June 15, 2011, 09:03:43 AM »
Thanks jenssen and yeah they're nice and tight I'll double heck after work and I just got the tires balanced last week at jays.
Dingman
« Reply #4 on: June 15, 2011, 09:08:50 AM »
Not caster. F-all to do with caster. Ever.
You have to dry steer test it before anything. Dry steer it, the harder the better, and see what has movement. Go from there.
What LCA's did you put in there?
« Reply #5 on: June 15, 2011, 09:11:47 AM »
with the rugged ridge you can fix the dead spot by getting a bushing for the tie rod end that connects the drag link to the tie rod. it will prevent the tie rod end on the drag link from rotating too much while you turn the wheel.
 it's pretty decent for the price I ordered the bushings from jcr offroad but rumor has it you can use  the upper bushing of a front shock.
Dingman
Are you running that steering? If you are, that deadspot is seriously contributing to your death wobble. The slack inherent with that system allows the tires to start shaking which can escalate into death wobble quite easily if the rest of the front end isnt ultra beefed up and tight.
« Reply #6 on: June 15, 2011, 09:18:15 PM »
Is the bottom hole(axle side) of the trac bar elongated?
« Reply #7 on: June 15, 2011, 09:28:01 PM »
Loose steering stabilizer + bad upper control arms I got it figured out thanks guys.
Dingman
