Author Topic: '87 YJ (43's, stretch, full width diffs, coil overs, small block, atlas, etc)  (Read 5707 times)
Offline muffintop
  • You spilled my macchiato!
Bought this rig out of the US as a runner but not nearly complete. This will now be a trail only rig (was street legal in Colorado)... so here is a summary of the mods underway and some build credits.
1) Engine... Cam, aluminum heads, tuned port injection (me)
2) Fuel system... 700HP Aeromotive pump & regulator, steel braided line, all AN fittings (me & RWS)
3) Dash/gauges/wiring... Autometer, 12 volt guy, painless fuse/relay wiring harness (me)
4) Steering... PSC full hydro (Bnine  & RWS)
5) Front suspension... air bumps & sway bar (Bnine & RWS)
6) Rear suspension... back half the frame (me & RWS)
7) Rear suspension... air bumps, swaybar (Bnine & RWS)
7+1) Exterior... TJ grill & TJ soft top (me)
Here are a few pics:
The rig as I got it out of the US:
Dash before
Dash in progress
Engine before
Engine in progress
Frame before
Frame in progress
Front suspension & steering in progress
Fuel system in progress
Still needs sway bars all around, rear bumps, final wiring and a bunch of test and tune time...
« Last Edit: April 22, 2013, 08:49:20 AM by muffintop »
2014 Jeep SRT
Offline apeman
  • not as grumpy
I used to have the same battery hold down.  Sweet  ;D
Getting grumpier every day.
Offline muffintop
Ya... I bought the rig out of the US and it worked OK... now I just want to bring it up to a "whole new level" and get rid of stuff like the bungie cord battery hold down system  :-[
« Last Edit: April 21, 2013, 07:03:27 PM by muffintop »
2014 Jeep SRT
Holy Crap Kevin... nice job on the YJ!!
Offline muffintop
Thanx for the props Dom... despite spending about 1/2 my time out of the country these days... I am hoping to have it out for a shake down run toward the end of July. I fired it up for the first time last week... so it's alive  ;)
2014 Jeep SRT
Offline mike s
  • Good times!
oldEnuff2NObetter
but still can't help myself
Offline muffintop
Fired it up, broke in the new cam, set timing & idle and then the computer took over... it runs really good. Sure seems snappy as compared to previous cam, heads and injection. Steering almost done (no pics yet).
Added shock tower brace that the PCS reservoir will mount to. From here its rear air bumps, sway bars, finish wire, proper fan mount, get red coil wire, etc... plus lots of little things.
Probably be ready for a fall run :)
2014 Jeep SRT
Offline turbolaser
hey muffin top did you make that steering wheel ?? the one with the holes in it ??
Offline muffintop
Nope... ordered it from PSC along with other steering parts...
2014 Jeep SRT
Offline muffintop
This rig is for sale and could be ready to go for May long weekend... see for sale section of this site for thread/post.
http://forum.calgaryjeep.com/index.php?topic=27475.0
KV
« Last Edit: April 21, 2013, 07:23:10 PM by muffintop »
2014 Jeep SRT
