Author Topic: Oh no, what did I do?  (Read 18052 times)
« on: October 08, 2011, 10:45:41 AM »
This might have been a big mistake.  :o
Re: Oh no, what did I do?
« Reply #1 on: October 08, 2011, 01:17:34 PM »
It is only a mistake if you do not put it in your jeep. hmmmm 6 litre? and nv4500.
« Reply #2 on: October 08, 2011, 02:01:16 PM »
You got a smokin deal on those items Klapper. You don't have to use it anytime soon , but it'll come in handy one day. My garage is full of crap that I've purchased in the hopes of one day using for something .
« Reply #3 on: October 08, 2011, 03:45:14 PM »
Yeah Six Liters of Doom. It's the 315HP version with 370ft/lbs of torque...with emissions and manifolds. I'm going to run w/o emissions and shorty headers so I have to build prepared for 400ish HP. I will probably look into running some sort of programmable tuner to keep the power down for now.
The price was so good I couldn't pass it up; I basically paid what the transmission (brand new) with shipping would be worth. Plus I couldn't think of any reason why not to. Besides you know, kissing my tcase, HP 'turdy and driveshafts goodbye. Now I'm hoping for a mild winter so it won't be -26 in my garage again!
Lots of work to do.
-Radiator, hoses, steam system, electric fans, shroud, wiring
-Engine + tcase mounts
-Atlas/StaK/D300, do I want passenger or driver side drop (ie, what axle am I going with), also changes exhaust routing
-Front axle, steering, track bar
-Air intake system (air box, tubing, possibly run LS1 intake manifold which gains hood clearance and hp but loses low end torque)
-Frame/cage?
-PCM marriage (run Jeep computer in tandem to allow gauge cluster to work, add in tachometer converter)
-Add fuel regulator, larger tank
At this point I'll be looking at tube fenders and some gnarly sized tires with hydro steer.
I think I'm going to stay with a driver side drop, truss the HP D30, stay on 33s for the winter and pray the 231 doesn't blow up.
Offline Raspberry
« Reply #4 on: October 08, 2011, 03:59:13 PM »
Take pics for us when it does  ;D
Offline The Machinist
  • I’m with stupid!
« Reply #5 on: October 22, 2011, 09:39:02 AM »
Great score!  Farmers almanac says it's going to be the coldest winter in 20 years!
« Reply #6 on: October 22, 2011, 07:29:13 PM »
I heard that. Luckily I have an ace in the hole; 80,000 square feed of heated shop space
« Last Edit: February 04, 2013, 11:17:25 AM by vantagetes »
Offline Waytec
  • not all there
« Reply #7 on: October 22, 2011, 10:22:32 PM »
 I am going to guess that you are working for Kidco because that is not the Finning Calgary Shop.
The obstacle is the path.
Offline Waytec
  • not all there
« Reply #8 on: October 22, 2011, 10:30:51 PM »
I will do show and tell as well. here is my crew pulling the 3516 out of a 793D, at the COE Red Deer, that engine is about 3 stories up. we needed to clear the cab to get it on the floor.
« Reply #9 on: October 23, 2011, 12:11:22 PM »
Good guess, you got it.
« Reply #10 on: October 23, 2011, 11:06:19 PM »
Divorced the engine and transmission and put the enine up on a stand. Any idea how much of a PITA it is to try to find M10x1.5x120 bolts to fit through the stand? Especially in grade 8+? Solution: use grinder to trim down tubes on stand, use M10x1.5x80 grade 12 bolts  ;D
After the engine was on the stand I pulled off the coil packs and exhaust manifolds/EGR.
Next step was to pour on the degreaser and wear out a couple SOS pads.
Looking much better, but still have some work to do.
« Last Edit: February 04, 2013, 11:18:15 AM by vantagetes »
Offline FirstTimer
  • Gettin there!
« Reply #11 on: October 24, 2011, 09:15:07 PM »
Looking good dude! Let me know if you need a grease monkey to hand you tools or beers! Would love the experience!
Offline JJonesee
« Reply #12 on: October 24, 2011, 09:40:52 PM »
Im trudging through the wiring/plumbing now.  you got a heck of a deal..
If you want me to try it out for you I could!
06' Rubicon LJ
52' M-100
82' Scrambler x 3
Offline Darkcalling
« Reply #13 on: November 14, 2011, 02:59:54 PM »
I second firstimers idea I would be love to come and absorb intel off this project as I have a similar goal and lighter is better more horses are a bonus :)
1999 Grand Cherokee Leredo 31s, 2000 TJ Sahara stock with 31s, 2007 Stang GT ragtop cold air and exhaust, 2011 Ram 3500 Cold air and exhaust so far.
Offline Elsifer
« Reply #14 on: November 14, 2011, 09:28:20 PM »
Whats a set of them "axel stands" worth?  ;D
After building natural gas compressors for a few years, I still love piping to those motors. And then watching the start-up. Damn, those things roar!  8) Me loves its!
VA6CPL
Jeepless....
