Author Topic: Removing a flywheel on a 2000 TJ 2.5l  (Read 1301 times)
Offline spoons72
« on: November 09, 2011, 10:59:33 PM »
Well,  I've got my engine out and a replacement ready to go in.  Trying to remove the 6 bolts on the flywheel from the old motor.  I only have a 13 gallon compressor which did nothing.  Tried my 4 foot snipe, that didn't seem to do much either although I really couldn't hold the crank well enough at the same time (if that's even the correct method).
Any advice would be appreciated.  Thx.
If I need a biggger compressor, good excuse to get it.
Re: Removing a flywheel on a 2000 TJ 2.5l
« Reply #1 on: November 09, 2011, 11:14:55 PM »
place ur 1/2 inch rachet and socket on it and smack it with a large hammer    it should break the bolts free
« Reply #2 on: November 09, 2011, 11:26:18 PM »
Yip x 2
Impacts also work wonders!
Offline spoons72
« Reply #3 on: November 10, 2011, 08:12:09 PM »
Thanks Rubi03 jef .  Worked like a charm.  Now I just need to get the rear main seal out.  Not having any luck there.
« Reply #4 on: November 10, 2011, 08:34:51 PM »
PA has internal seal pullers for pretty cheap, can't remember if I have one collecting dust in my toolbox or not.
« Reply #5 on: November 10, 2011, 11:14:02 PM »
Rear main  or pilot bearing
Rear main pull the oil pan. And then remove the most rear bearing cap the seal is under that
Pilot bearing.  I have a pulled if u need one let me know I'll bring it home from work tonight
