Author Topic: Limit Straps  (Read 2034 times)
Offline MOABICON
  • MOABICON
Limit Straps
« on: January 03, 2012, 09:58:17 PM »
Anyone ever install limit straps on a 03 TJ, front.
How do you attach them to the shock tower on the
top and attach to what on the bottom. Thanks (-:
Re: Limit Straps
« Reply #1 on: January 04, 2012, 12:18:40 AM »
You fabricate mounts.
What kind of 2" lift do you have that requires straps?
Re: Limit Straps
« Reply #2 on: January 04, 2012, 01:47:00 AM »
good point
Re: Limit Straps
« Reply #3 on: January 04, 2012, 09:24:36 AM »
If you are worried about it at 2" just leave the sway bar hooked up. You'll still have enough flex to get over the parking blocks at the mall.
 :D ;D
Offline MOABICON
  • MOABICON
Re: Limit Straps
« Reply #4 on: January 04, 2012, 09:46:39 PM »
Why limit straps? This summer at McLean I over extended my right front shock.
Then, it jammed. When the axle came back up, the shaft couldn't go back into
the cylinder. It bent the shaft, then pushed through the washer on the bottom
side of the shock tower, (one just below the bottom rubber), then continued up
through the hole in the shock tower, through the fender and then into the bottom
of my air box! Thought I would just try and prevent this from happening again.
Then, there is of course, the "kool factor" of having limit straps.  (-:
Re: Limit Straps
« Reply #5 on: January 04, 2012, 10:40:07 PM »
Okay....that begs the question "is your shock the right length for your lift?"
Re: Limit Straps
« Reply #6 on: January 04, 2012, 10:54:38 PM »
Yip, sounds like a short, inexpensive, white bodied shock stamped " hecho en Mexico" with some fancy name brand sticker on it.
Kool factor of limit of limit straps? Dunno about that.
More like cheap insurance when your shocks cost $800-$1500 per corner.
Offline MOABICON
  • MOABICON
Re: Limit Straps
« Reply #7 on: January 05, 2012, 08:58:23 AM »
The shock that got bent was an origingal stock shock. I now have
two new front shocks from Zone Off Road. They are BDS shocks
for a 2" lift. Also, have a Zone HD stabilizer shock. All work well.
Re: Limit Straps
« Reply #8 on: January 05, 2012, 09:23:51 AM »
New shock intended for the lift height you have  = problem already solved. If you want to add limit straps for the cool factor, knock yourself out.
Now you're on to the new problem that Frenchy was talking about. Zone paints their shocks white, right?
Offline MOABICON
  • MOABICON
Re: Limit Straps
« Reply #9 on: January 05, 2012, 03:49:22 PM »
El choque es si blanco. Hecho en Mexico. (-:
Offline binare
Re: Limit Straps
« Reply #10 on: January 05, 2012, 04:56:08 PM »
Why does everybody think that if bds owns zone they are the same shocks? I highly doubt it... good way to kill a brand. Are Lambos made in a Chrysler factory? Doubt it. You bought cheap shocks so save up till they go on you as well and buy some good ones.
Offline esi
Re: Limit Straps
« Reply #11 on: January 05, 2012, 10:10:49 PM »
Why does anyone think BDS makes a decent shock? ???
Formerly of Boots & Boost Inc
Offline homeguy
Re: Limit Straps
« Reply #12 on: January 05, 2012, 11:17:51 PM »
Isn't Zone owned by Rubicon Express?
Offline NUXJR
Re: Limit Straps
« Reply #13 on: January 06, 2012, 10:15:55 AM »
Rubicon Express is owned by 4wd hardware or something like that.  Don't know about Zone
Re: Limit Straps
« Reply #14 on: January 06, 2012, 10:22:49 AM »
all whitebody type shocks (the cheap line of any brand pretty much) are all made in the same factory, to the same specs etc.
so who cares what sticker you put on it?
BDS owns Zone.  Zone is a knockoff of BDS.
