Author Topic: Anybody done DIY on-board air system  (Read 9358 times)
Offline Dirt Addiction
  • Stuck
« on: January 26, 2012, 02:12:49 PM »
I would like to get an on-board air system. Anyone know of a way to do this for under $200.00?
Offline Full Metal Jeep
Re: Anybody done DIY on-board air system
« Reply #1 on: January 26, 2012, 02:15:37 PM »
I know there is a way to do it by tapping into your stock air compressor (rubicons), and is a matter of rigging in a reserve tank and a few lines... but I dont know much more than that, I am going to be looking into this in more detail soon as I would like to add this option to my rubi.
"There's "to each his own" which I know all you hippies are so fond of around here, and then theres just plain stupid." ~ Bnine
« Reply #2 on: January 26, 2012, 02:16:25 PM »
This is my writeup on what i hooked up...
http://forum.calgaryjeep.com/index.php?topic=21332.0
« Reply #3 on: January 26, 2012, 02:40:19 PM »
Don't those pumps only put out about 3Psi ?
« Reply #4 on: January 26, 2012, 02:59:19 PM »
you will have to gut your AC system to do it under 200$
it can be done though.
or just go buy an ARB compressor.  bolt in and go.
« Reply #5 on: January 26, 2012, 03:26:45 PM »
are there any benefits to going with an ARB compressor vs the Warn Power plant winches??
« Reply #6 on: January 26, 2012, 03:40:05 PM »
The Sanden 7 series which I have puts out about 9 when converted. At least this is the general consensus... They were never spec'ed to do this so its not really posted information thats easily found :)
Offline IgniteTJ
« Reply #7 on: January 26, 2012, 03:47:18 PM »
I've had a couple friends run the power plant winches now and they weren't too impressed with them.. Just too much stuffed into one unit I guess?
« Reply #8 on: January 26, 2012, 03:52:04 PM »
yea thats what I figured.
that sir, is a sick set up, but a little past my skill level I think...
Offline binare
« Reply #9 on: January 26, 2012, 04:37:22 PM »
Just for tires or tools too?. I got a Viair 400h for about 220. Perfect for tires and less then an hour to install.  Add a tank later on to run tools if you want.... but IMO these setups are pretty well pointless for running air tools no matter how good they are.
« Reply #10 on: January 26, 2012, 05:18:34 PM »
Honestly not that hard! If you want a hand or have questions let me know. im free to answer as best I can. Just will be movin to Red Deer in the next couple weeks so wrench time will be limited...
Offline AstraX
« Reply #11 on: January 26, 2012, 05:54:41 PM »
The ARB is a slick little setup.
It's a little more then $200, but it comes with everything you need.  I'm sure Stan will give you a discount as well.
http://www.northridge4x4.ca/proddetail.php?prod=ARB-PKG_JK_AIR
Offline AstraX
« Reply #12 on: January 26, 2012, 05:56:21 PM »
I have an air tank...I may con you into coming over to help me set something up one of these days.  :)
Offline Waytec
  • not all there
« Reply #13 on: January 26, 2012, 07:05:10 PM »
I did something very similar to what TL-Iguana did. at first a ran a external oiler, then switched over to a grease-able set up.
here is my build http://forum.calgaryjeep.com/index.php?topic=16374.0 . You are going to have to look over the first set up and second to see the whole thing.
What are you wanting to do with the set up? unless you are willing to lose a/c or shell out the cash for a engine driven pump, you are going to be in the same boat as just getting the ARB or one of the other guys that are building the same thing. If the only resin is to run air tools, I have never used air tools on the trail. and to change a tire, you can spin the nuts off faster with a tier wrench . Kevin runs 2 sets of wheel, one street and one trail and changes in camp but he still uses the ARB. and if it is a setup to reseat a bead you can get a ARB, and a small CT pig and change it to be a reservoir for the air blast.
There is a lot of options and it comes down to what you are looking to do with the set up and how much cash you want to spend.
BTW a A/C conversion  without already having tanks will set you back just over $200 budget for $300 to be safe. Brass firings and steal braded hose is not cheap even at PA. it all adds up in a hurry.
The obstacle is the path.
« Reply #14 on: January 26, 2012, 07:58:23 PM »
i had a powerplant .. good strong but they do have issues .. so try to stay away from them
