Author Topic: My Injector Upgrade Experience  (Read 4284 times)
Offline Nootch
« on: February 02, 2012, 10:52:13 PM »
Was reading a bunch of online forums on the jeep injector upgrades and how the mustang ones plug right in, but flow a lil bit heavy for a stock config.  Was just about to order them up when i came across an article talking about the Neon's injectors and how they flow nearly identical, but are a 4 hole set up vs a single hole. After a few trips to my local wreckers i was able to get a few rails to play with.  the numbers i was looking for are Bosch 0 280 155 703's and the 0 280 155 784's.  They are both the same, but the 703's ended up having a older style injector clip and the 784's were a direct fit.  I ended up converting two of my clips to match the 703's and will go back to the stock set up when i find more later on.
First thoughts were how much better the jeep started and idled.  super smooth.  not much more power that i can see, but i haven't been to WOT or in the crap with it yet.  but the fuel economy has been a major improvement.  with a light foot to break in my new gears, i am getting almost twice as much to my tank as normal.  but as my regular driving style, i am going to estimate a good 20% gain if not more. Will know more once i fill up and take a known distance cruise to edmonton from red deer.
This is something i would recommend most users looking into.  it was a simple job done on my gravel pad.  in and out in an hour, and most of that was cleaning the injector areas before i took them out.
**EDIT**  running a 4.0 in a 2kTJ
« Last Edit: February 02, 2012, 10:53:56 PM by Nootch »
Re: My Injector Upgrade Experience
« Reply #1 on: February 02, 2012, 10:57:43 PM »
your gains are likely because of the gear swap, not the injectors..............
Offline Knox
« Reply #2 on: February 03, 2012, 07:13:05 AM »
aye the start up and idle is a great thing that it all worked out, but what new gears did you put in? what size tires.
2003 TJ
« Reply #3 on: February 03, 2012, 08:13:49 AM »
I swapped in the yellow top mustang injectors into my YJ and it definitely was more responsive and my fuel economy increased (approx 2l/100km improvement).  However, that was probably more due to the fact that I replaced the original injectors after 250,000 kms.
My Jeep runs a lot better after the swap
« Reply #4 on: February 03, 2012, 06:05:52 PM »
good swap. what year of neons did you get the injectors from? the part numbers should help though.
Offline Nootch
« Reply #5 on: February 03, 2012, 09:48:20 PM »
The gears would def figure some of it into the equation, but i had put 4 tanks through the gears before the injectors.  wasn't a big gain there as my highway speeds on 3.07's with 35's was 3rd gear.  now with 5th gear (using 4.88's) i am running near the same rpm's.
what i found locally was a bunch of 0 280 155 703's and some 0 280 155 784's, as see on the side of the injector.  the 784's are a direct fit to the wiring harness, and the 703's need to convert the wiring. but they are the same guts inside for the injectors.
the chart i used was this
Offline CatSplat
« Reply #6 on: February 04, 2012, 10:27:56 AM »
703's are most easily found in Stratuses and Cirruses, I never did find a Neon in the JY with them. EV3 rebuild kits (filters/o-rings/caps) are available online for pretty cheap.
I think the injector plug change happened in '99, the older models have the Jetronic/Minitimer connector while the newer ones use the USCAR connector. I believe you are correct that the internals of the 784s and 703s are identical but I've only flow-benched the 703s so I don't know for sure.
Jeep of Theseus
Offline Nootch
« Reply #7 on: February 07, 2012, 09:10:03 PM »
after some more driving i am noticing that these were the way to go.  getting about 80k a tank more right now i figure. going from my place to Northridge and back used to be 3/8 a tank, now its 1/4
