Author Topic: Rubicon Express Trackbars  (Read 2593 times)
« on: May 01, 2012, 08:52:42 AM »
almost got 2000k out of the RE trackbar i installed last october.  oh joy.
anyways, the heim in it is shot, its creeking badly and clunking.  just wondering if anyone knows the size offhand so i can rip down to Greggs and buy a couple.
Re: Rubicon Express Trackbars
« Reply #1 on: May 01, 2012, 09:04:00 AM »
Pretty sure evolution makes one in Irracana that will last a lot lot longer.
Sent from my I junk
« Reply #2 on: May 01, 2012, 10:21:00 AM »
A cheap RE component that didn't last? Who would have expected that?
Offline OnyxGrizzly
  • Just another red XJ
Re: Re: Rubicon Express Trackbars
« Reply #3 on: May 01, 2012, 10:22:36 AM »
My trackbar did the same thing......... Haha
Sent from my HTC-X710a using Tapatalk 2
If you don't stand for something, you'll fall for anything.
« Reply #4 on: May 01, 2012, 10:38:26 AM »
moderns got em on the shelf so off i go!
Offline dubbleJs
« Reply #5 on: May 01, 2012, 11:25:44 AM »
Yea....RE heims and their crap LCA spherical ball joints don't last long... >:(
Modern had 'em last time I was there as well.
« Reply #6 on: May 01, 2012, 11:28:37 AM »
yup. but at the time it was either this, which was on the shelf or wait a month for something else.  i was daily drivin it at the time, so i needed one.
i have a plan; i'm gonna build a boot for the heim, and fill it with grease, see if it helps keep it alive longer.  then sometime after the wedding and money's a little less tight order up an IRO double sheer or something along those lines.
but for now this gets me back on the road.
« Reply #7 on: May 01, 2012, 01:52:39 PM »
Why do people always assume that poor planning is a valid excuse bad decisions..................
How much is that 10$ heim at modern? It probably wont match this for quality but cost at least double
http://www.ruffstuffspecialties.com/catalog/3458RE.html
More then likely it will resemble this
http://www.wfoconcepts.com/pr/34-x-58-Bore-Male-Heim-Joint,-LH/3199/3260/3269
« Reply #8 on: May 01, 2012, 05:31:59 PM »
always learning............ its a lifelong event :)
thanks for those links tho Bill. i'm looking at ordering the ruffstuff ones right now!  maybe i'll order a few.  :)
« Reply #9 on: May 01, 2012, 06:24:02 PM »
Ya man, ruff stuff is a good place.
Offline CalJeez
« Reply #10 on: May 02, 2018, 11:37:02 PM »
Hi! Changed my stock track bar for the adjustable one. Just wanted to know something about Rubicon Express. Has anyone here experience noise when you installed it onto the Jeep? What could be the problem? I tried to follow the instructions and thought everything will be okay. However, when I turn steering it creates a noise that something might be loose.
« Reply #11 on: May 03, 2018, 11:26:19 AM »
Try tightening down both ends. The holes wallow out over time and it may not be as tight as you think it really is.
Offline Sixty4X4
« Reply #12 on: August 20, 2018, 07:29:30 PM »
Bit old this post but here is my take on HEIMs - I WILL NOT USE ANY HEIM. They are good for a short while what they were designed for. BTW - you can buy rubber grease seal boots for most HEIMs if you still want to use them. I would like to see Transport Canada ban them for on road vehicles. Trust me I had experience on a high performance car with them. Never again for anything.
2008 JKU Ruby, Jeep steel bumper, 9500 winch, 2016 5.3 Chev LT & 8L90 8 spd auto, 285 Maxxis Bighorns, MC 2.5" and LC Arms.
