Author Topic: Troubles starting and keeping 4L running  (Read 8338 times)
Offline Pookapotamus
Re: Troubles starting and keeping 4L running
« Reply #15 on: May 23, 2012, 08:18:44 AM »
nope i never had the front cover off, and it ran great before we pulled it.
Nathan did you use the same flywheel that came on the renix or did one come with the 97 tranny?
pook
« Reply #16 on: May 23, 2012, 09:47:12 AM »
On the renix the cps is by the harmonic balancer and the ho the cps is of the flywheel. Did you swap out all the renix fi for ho fi on the swap as ?
Sent from my I junk
« Reply #17 on: May 23, 2012, 10:14:49 AM »
The CPS was at the flywheel on the renix with the 97 tranny.  Replaced the CPS with a used (new to the harness) CPS.
I farted around with dist last night.   When things where running rough, the rotor was pointing between 1 and 4 on the cap.  That was with the slot at 11 o'clock.
I moved it over to the 9 o'clock position at the rotor is now pointing just before the 1 wire now.  I will try to fire it up after work and see if that makes a difference.  I think that should be one tooth over...
« Last Edit: May 23, 2012, 10:24:39 AM by specialk »
Offline XJHERO
  • Soberphobic
« Reply #18 on: May 23, 2012, 11:00:13 AM »
pook
Sorry I don't recall if I did or not!
DD
Get at me Wolf
« Reply #19 on: May 23, 2012, 04:17:43 PM »
Tried turning it over a nothing, so the original position of the dist was probably correct...
Offline raf2379
« Reply #20 on: May 23, 2012, 05:16:25 PM »
Kevin do you have a compression test kit? if not you can borrow mine, test your compression.
Offline jkrubi
« Reply #21 on: May 23, 2012, 05:44:16 PM »
Your guessing at timing. Set it up for #1 TDC on compression ( you should be close to 0 on the timing mark in the crank) and reinstall the dist so it's firing #1. You may have to remove the valve cover to make sure that the valves  are still closed and your at TDC.
Next thing I'd check is the gap at the pick up sensor  for the cps?
Do you have the correct computer for this eng? Try using that one maybe the location of the cps has a different value to it?
Have you checked that all vacuum lines are on and correct?
Everything electrical is connected up, all grounds are good?
Just a few more things off the top of my head.
« Reply #22 on: May 23, 2012, 05:57:53 PM »
Great ideas...
Yes - computer and harness were the ones with the engine orginally... not sure about the CPS (Pook?)
Vacuum lines appear good
We think we have the grounds all done...  farking jeeps....
I'm going to get in touch with Jessen and see if get a CPS to swap in and try...  (unless some one else closer to me has one...)
Offline BUKI
  • Project Fugly
« Reply #23 on: May 23, 2012, 06:23:00 PM »
Ok 3 stupid questions
1.  How hard is it to pull the cps?
2.  Are the cps's all the same (tj,xj/mj)??
3.  If so, why don't you swap in the one from your tj (you know it's good)
« Last Edit: May 23, 2012, 06:25:16 PM by BUKI »
« Reply #24 on: May 24, 2012, 07:08:15 AM »
yet everything is the same as to how I ran this engine. only thing different is the drive train.
Pook
« Reply #25 on: June 03, 2012, 05:37:05 PM »
We got it running!!!!   ;D
So XJWrencher wins for the fly wheel idea.   The fly wheels are completely different from the 89 and 95.
After changing that out,  we had to cut the ears off the distributor so we could advance the timing.   Runs like a charm now!
Thanks for all the ideas!
« Reply #26 on: June 03, 2012, 09:25:22 PM »
come on... film it. We want to hear it puuuurrrr!
« Reply #27 on: June 04, 2012, 12:26:54 PM »
Sounds like you are out a tooth if you have to addjust the distributer.
« Reply #28 on: June 04, 2012, 12:48:23 PM »
That makes sense Bill and we tried that...  it just didn't want to catch...  It seemed no matter how we moved the dist around we always had spark before we hit TDC.  That being said,  we only did try one tooth in each direction.  It's possible that going 2 teeth would have put the distributor the right spot.
I've got another distributor and new CPS now (we had older ones in there when we got it started) ...  I'm going to try swapping those in and see if I can keep this thing running...
Big thanks to Ron and Dana for your help!
https://plus.google.com/u/0/photos/fromphone/5749586167726581538
« Last Edit: June 04, 2012, 12:53:57 PM by specialk »
