Author Topic: Catalytic converter  (Read 3943 times)
amo
Catalytic converter
« on: June 16, 2005, 11:34:34 AM »
I need to replace catalytic converter in 97TJ SE 2.5L, and I was checking prices in Calgary... they want about $450 for everything.
Does anyone know where I can do it for cheaper with aftermarket parts.
RedYJ
Catalytic converter
« Reply #1 on: June 16, 2005, 09:27:14 PM »
If im not mistaken you could just get it hollowed out or a pipe welded in its place for cheaper.  Unless you want to keep your cat.
Catalytic converter
« Reply #2 on: June 16, 2005, 09:30:16 PM »
The the stupid cat out and put in a resonator.  As long as your O2 sensors are before the cat, no problems, which i believe they are before
Offline DGenR8
Catalytic converter
« Reply #3 on: June 16, 2005, 10:27:30 PM »
I just had the cat taken out of my 97 TJ at Calgary Muffler, cost $100.
Runs better than ever.  8)
_/l ,['''`'''],
l---L--OllllllO-
81 CJ7
henry
Catalytic converter
« Reply #4 on: June 17, 2005, 05:54:16 PM »
I guess we're not concerned about Hydrocarbon Emissions then eh!!
Darren
RedYJ
Catalytic converter
« Reply #5 on: June 17, 2005, 09:18:29 PM »
hydro what now?
felves
Catalytic Converters
« Reply #6 on: June 20, 2005, 07:55:57 PM »
I have the same TJ but mine is a 4.0 ltr. My oxygen sensor is after the converter and I wonder if I remove the converter will it ruin the settings for the computer through the oxygen settings. I have sent a email to chrysler and will let you know the reply.
Fred
RedYJ
Catalytic converter
« Reply #7 on: June 20, 2005, 08:04:50 PM »
Quote
 I just had mine out on my YJ there today.  Great service but mine only cost $69.99  :D
Re: Catalytic Converters
« Reply #8 on: June 20, 2005, 08:10:50 PM »
Quote from: "felves"
Fred
It will run like ABSOLUTE CRAP!!!  You can only remove your cat if the O2 sensor is in front of the cat.
Offline DGenR8
« Reply #9 on: June 20, 2005, 09:56:53 PM »
Quote from: "BlackYJ"
Actually the TJ has an O2 sensor before and after, the one after does not change any of your air idle settings, you can remove the cat but they have to put the O2 sensor back in. That was why mine cost $100 not $70
_/l ,['''`'''],
l---L--OllllllO-
81 CJ7
amo
Catalytic converter
« Reply #10 on: June 21, 2005, 01:59:57 PM »
The catalitic converter is covered by Jeep up until the 130.000 km or 5 years - whitchever first.
I found a guy in NE that will instal the after-market  replacement - all for $260 - 300 CAD.
amo
Offline Elsifer
Catalytic converter
« Reply #11 on: June 21, 2005, 03:00:46 PM »
I don't know about you, but I like to breath clean air. Vehicle exhaust is nasty enough!
Cheers
Chris
VA6CPL
Jeepless....
felves
Catalytic converter
« Reply #12 on: June 21, 2005, 08:36:09 PM »
Well I did it I had a straight length of pip put in the place of my hatched converter on my 4.0 TJ. As the oxygen sensor is in the middle of the converter you have to have a plug put in the pipe to accept your oxygen sensor which must be in the system. Thought you would like to know
