Author Topic: E-mortal's (off road evolution) bulk order on now  (Read 1448 times)
Offline LEMON-AID JAY
  • Bad a$$ zj owner
« on: October 17, 2012, 07:41:21 PM »
http://www.offroadevolution.com/news/?p=15
Bulk order on now for all off road evolution gear  ;D
Special Deals on off road evolution bolt on coilover kits for jk's :o
EVO MFG LCG front Bolt-On Coilover Kit for Jeep Wrangler JK
With a foundation in the first and most proven coilover systems for the Jeep JK, EVO MFG brings you its new LCG Bolt-On Coilover System./br>
The EVO LCG Bolt-On Coilover kit comes complete with all necessary parts to easily convert the JK from the limited coil and shock system to a far superior performing coilover system.
With 12” of usable wheel travel, custom built brackets for the lowest center of gravity and EVO’s legendary SPEC valving and spring rates, the EVO LCG Bolt-On Coilover system proves to set the bar, for ease of install, price and performance.
http://www.offroadevolution.com/store/proddetail.php?prod=EVO.Bolt.On
HOME » OFF ROAD EVOLUTION » SUSPENSION / STEERING
EVO MFG NEW BOLT ON COILOVER KIT (REAR)
EVO-1109 Rear EVO LCG Bolt-On Coilover Kit (with EVO SPEC C/Os)
Simple and quick installation
LCG 3”-5” recommended lift height, Fully adjustable Minimal Drilling/Cutting required, fully bolt-on Hi Clearance design Retains all factory rear exhaust system Retains factory front and rear swaybars Kits contain all necessary parts to convert a standard coil spring suspension system into a coilover spring system. Can be used with any long or short arm system
Recommended wheel backspacing 3.75” or less (smaller backspacing #)
2Door JK: Front and Rear Aftermarket Driveshaft Required
4Door JK: Front Aftermarket Driveshaft Required, Rear Recommended
http://www.offroadevolution.com/store/proddetail.php?prod=EVO.Bolt.On.R
If there is anything your interested in please give us a call, post up here or PM me  ;D
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
