Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
xj 4.0l revs high and low.
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: xj 4.0l revs high and low. (Read 2280 times)
99xj
Stocker
on:
December 16, 2012, 12:28:53 PM »
Hello this is my first post in the forum. Yesterday noticed my jeep when idle for couple mins would try to stall then rev high. Also sometime while driving feel cutting out!!!
Since then today I have flushed fuel system and cleaned TB. Also replaced TPS sensor. But is still acting up.
Motor is stock besides gforce chip and throttle spacer. Please any ideas or help greatly appreciated
Logged
99 xj 6.5 iron rock long arm 33's
02 tj 4' rough country 33's sold
yellowjeep101
Budget Lift
Re: xj 4.0l revs high and low.
Reply #1 on:
December 16, 2012, 01:04:46 PM »
Check engine light? If so, check the code. Check the code anyways, maybe your check engine light is burnt out. I'm thinking you have a o2 sensor that is done.
Logged
99xj
Stocker
Reply #2 on:
December 16, 2012, 01:20:25 PM »
the check egine is not on at this time and since started idle problem. But has came on and off over last couple of weeks
Logged
99xj
Stocker
Reply #3 on:
December 16, 2012, 02:09:48 PM »
after reading some forum post i see could be IAC valve so just got one from napa I'll see if this is the fix
Logged
99xj
Stocker
Reply #4 on:
December 16, 2012, 03:15:19 PM »
replace the Idle control valve. didnt fix it. now after jeep gets to running temp at idle it will act up rough idle. If I turn it off and back takes about 10 minutes of idling for it to do it again...
Logged
apeman
Talks waaay too much!
not as grumpy
Reply #5 on:
December 16, 2012, 03:20:08 PM »
Most likely the upstream 02 sensor.
Logged
Getting grumpier every day.
99xj
Stocker
Reply #6 on:
December 16, 2012, 03:35:09 PM »
Ok thanks I see yourself and yellow jeep think is the samething. I am going to give that a try thanks to you both
Logged
99xj
Stocker
Reply #7 on:
December 17, 2012, 03:26:55 PM »
Today I checked codes, Nothing, swapped o2 sensor main stream. But still when get to 100 temp will start to idle rough up and down. once turned off will run fine again for 10 mins or so.
Logged
WagoneerXJ
Bagon Wagon!
Reply #8 on:
December 17, 2012, 03:48:38 PM »
G force chip? That the resistor thing from ebay?
Logged
84 Mustang GT-Built 351W 5spd
WhiteOut
Reply #9 on:
December 17, 2012, 03:49:50 PM »
Best place to start is to remove the chip.
Logged
99xj
Stocker
Reply #10 on:
December 17, 2012, 04:41:46 PM »
I removed it but still does same either way. Totally stumped now.
Logged
99xj
Stocker
Reply #11 on:
December 17, 2012, 04:43:00 PM »
the Gforce chip Im not too sure it was installed when I purchased jeep.
Logged
apeman
not as grumpy
Reply #12 on:
December 17, 2012, 04:58:15 PM »
Coolant temp sensor malfunction.
Logged
99xj
Stocker
Reply #13 on:
December 17, 2012, 05:05:45 PM »
where abouts could I located that under hood. I will give that a try thanks.
Logged
yellowjeep101
Budget Lift
Reply #14 on:
December 17, 2012, 08:33:24 PM »
I'm still thinking its your o2. I had similar issues and all it was was that sensor
Logged
Print
Pages: [
1
2
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
