Author Topic: XJ help please  (Read 1897 times)
Offline Maciej
XJ help please
« on: October 12, 2013, 07:51:47 PM »
Ok so i just bought a 94 cherokee sport its got 285000kms on it.
Ive been slowly looking things over and came across this problem...
The airbox is getting oil into it coming from the calve cover i believe it is.
Its the tube in the picture that im pointing at. Can anyone let me know whats going on and how i could go about fixing it.
2011 2dr JK
Offline The Machinist
  • I’m with stupid!
XJ help please
« Reply #1 on: October 12, 2013, 08:03:00 PM »
It's caused from excessive blow-by.  The rings are worn and compression is blowing by into the crank case.  It vents through that tube and oil will start coming through there when there is too much pressure.  You can run the tube in to a vented container and pour it back in to the engine when it gets full.
Re: XJ help please
« Reply #2 on: October 12, 2013, 09:01:32 PM »
Mine was doing the same thing. The line going into the valve cover close to the firewall by the yellow fuse box? Was plugged.( Some models it is the pcv). Cleaned it out , made sure air could flow through. All is better.
In theory filtered air is supposed to be sucked in from the air cleaner. And crank case fumes sucked into a port on the intake manifold.
Offline Maciej
Re: XJ help please
« Reply #3 on: October 13, 2013, 08:26:56 AM »
Thanks guys. So is this a common issue. Should i be worries about it or is it not serious at all.
2011 2dr JK
Offline BUKI
  • Project Fugly
Re: XJ help please
« Reply #4 on: October 13, 2013, 09:11:27 AM »
Maciej this is very common and I have had this issue since I bought my current yj and had same thing with last yj. You tube oil catch can 4.0l jeep. I did it no issues. And it saves your air filter. Blow by just happens. Try cleaning the crap outta the pcv valve first though. Then worry about the catch can.
Sent from my iPhone using Tapatalk - now Free
Offline JENSSEN
    • Racing For The Cure
Re: XJ help please
« Reply #5 on: October 13, 2013, 09:55:51 AM »
Once the PCV valve is cleaned run some Lucas oil works lie a champ!
www.racingforthecure.ca
Offline Maciej
Re: XJ help please
« Reply #6 on: October 13, 2013, 10:25:57 AM »
Which is the pcv valve?
Sorry im less than knowledgeable when it comes to motors
2011 2dr JK
Offline BUKI
  • Project Fugly
Re: XJ help please
« Reply #7 on: October 13, 2013, 01:40:54 PM »
Pcv. Positive crankcase ventilation is the doohickey on the top of your valve cover looks like a 90* elbow. Remove it carefully. As it will break.
Offline Maciej
Re: XJ help please
« Reply #8 on: October 13, 2013, 02:34:14 PM »
Thanks mike
2011 2dr JK
Offline afb
Re: XJ help please
« Reply #9 on: October 13, 2013, 07:18:43 PM »
I had the same thing and when I took my head off all the oil being sucked up over time hardened up on the intake valves. I lost 30% volume in each intake and the exhaust was just as bad. The engine had 155000km when I pulled it last year. Easiest thing to foo to help clean it without rebuliding the head is use seafoam.
'93 yj 2.5 with all the engine mods done so I can beat a kid on a tricycle in a race.
