Author Topic: jk sway bar disconnects, Yes or no?  (Read 2381 times)
Offline johndeeretimex
« on: February 12, 2014, 10:28:46 PM »
Should I be adding a diy jk sway bar disconnects? I am a easy going wheeler with a stock jk and need the jk for a everyday driver as well. Looks easy to instal and upgrade too. Would like some feed back on stock jeeps with them!
Re: jk sway bar disconnects, Yes or no?
« Reply #1 on: February 12, 2014, 10:40:01 PM »
just unbolt the stock one and push it out of the way.
been doing that for years.........
« Reply #2 on: February 18, 2014, 08:00:33 PM »
Great I looked into it and say the jks are a easy install and user friendly thinking of those ones might work
Offline canthonyparkinson
« Reply #3 on: February 19, 2014, 04:29:08 PM »
As the driver of a JKU Rubicon, I can tell you that I use the Sway Bar disconnect way more often than the lockers.  Go for it.
Anthony Parkinson
2013 JKU Rubicon
« Reply #4 on: February 28, 2014, 01:19:36 PM »
Well it took longer to finish my sub than it did to put the bars on! They work great just need a good way to keep it up wile it is free
Offline dubbleJs
« Reply #5 on: February 28, 2014, 02:23:39 PM »
Not sure how its set up on a JK but we zip tie my brothers Jks disconnects up on his XJ through a hole in the frame rail. Use metal zip ties though as the plastic ones tend to break
« Reply #6 on: February 28, 2014, 04:21:14 PM »
Don't they come with storage pins you put on the frame like the TJ's?
« Reply #7 on: March 01, 2014, 01:26:26 AM »
Or a couple bolts put through the sheet metal work as well... Use a washer and a 2nd nut to hold it on.. But yes, should have come with pins.
