Author Topic: Ramping....  (Read 11332 times)
Ramping....
« on: June 20, 2005, 05:29:17 PM »
I need help with the Ramp next Saturday (06/25) @ National 4WD Centers.
Can someone give me a hand with that? PLEASE!!!!! 8)
I know how to do the calculation but I've never seen it done.
Please let mek know...
Dom
Ramping....
« Reply #1 on: June 20, 2005, 06:22:40 PM »
Dom, I won't be able to help you on this one
But here is the low done
1.  Measure the wheelbase.  Best way it to go from outside rim edge to outside rim edge.  Just make sure if you measure from the leading edge on the front you measure to the leading edge on the back.
2.  Vehicle drives up
3.  Measure from the center of the front wheel down to the start of the ramp.
4.  Take the distance travel up the ramp and divide it by the wheelbase
5.  Multiple by 1000.
6.  Have a BEvERage.
Ex.  If my YJ (WB = 93.4") drove up the ramp a distance of 73", then my score would be 73/93.4*1000 = 782
Here are a couple of links
http://www.offroaders.com/info/tech-corner/rti.htm
http://www.landyonline.co.za/techtalk/rti.htm
If you need more info, I can meet up with you sometime this week
JUST MAKE SURE TO BRING A CALCULATOR!!!
Ramping....
« Reply #2 on: June 20, 2005, 06:49:18 PM »
Thanks Scott!!!   8)  :)
Offline Mudhawg
  • Rig Life
Ramping....
« Reply #3 on: June 20, 2005, 06:51:00 PM »
hey dom i have to go to ure place sometime if ure holding the RTI ramp and ramp my RC truck and the Flex monkey jeep   :lol:
Ramping....
« Reply #4 on: June 20, 2005, 06:54:26 PM »
Quote from: "Mudhawg"
 :lol:  :lol:  :lol: ....
Offline TJ54
Ramping....
« Reply #5 on: June 20, 2005, 09:54:00 PM »
Maybe, I will let you know for sure on thursday PM.
Been kinda busy at work lately, so I can't  promise 'till then.
Ian
Offline Elsifer
Re: Ramping....
« Reply #6 on: June 21, 2005, 09:26:33 AM »
Quote from: "SwampSinger"
I don't know how to do them either, but with Scott's directions, and the use of a calculatrice, we should do ok.
I'll give you a hand, let me know the details, when, where, etc.
Cheers
Chris
VA6CPL
Jeepless....
Offline Mudhawg
  • Rig Life
Ramping....
« Reply #7 on: June 21, 2005, 06:33:36 PM »
if i can get a ide me and my RC will be there  :lol: git er dun
Re: Ramping....
« Reply #8 on: June 21, 2005, 06:41:58 PM »
Quote from: "Elsifer"
Cheers
Chris
Right on!!!  :D  :D  :D  :D Thanks Chris and Ian... I'll have the details tomorrow (06/22) 8)
Dom
Ramping....
« Reply #9 on: June 22, 2005, 12:31:06 PM »
BEWARE of cheaters :D
Cheating on a ramp is when you only air down 2 tires and not 4.
Cheating on a ramp is also when you air down below the psi you normally run on the trails.
Cheating is when you disconnect your shock.
Offline Elsifer
Ramping....
« Reply #10 on: June 22, 2005, 12:39:32 PM »
Quote from: "Spinalguy"
OK, how about swaybars and trackbars?
What about not airing down at all? (Or which two tires?)
VA6CPL
Jeepless....
Ramping....
« Reply #11 on: June 22, 2005, 02:58:18 PM »
Basically, you set your rig up as you NORMALLY would for a trail ride. If you only go down to 15psi, than that is how you should ramp it.
If you disconnect swaybars, than go do it for ramping.
If you have no trackbar, than no need to get one :)
If you want to see the difference airing down makes, give it an "unofficial" try at lower psi, about 10psi would probablly score about 2-300 higher than 15psi. And when you see the difference, you may even try a trail at that psi to see how much more performance you may gain :wink: And next year you can ramp it "officially" at 10psi :lol:
The biggest advantage you can get is letting air out of the front driver and rear passanger, this will produce the highest score.
The measurement is taken at the point that the rear driver tire starts to get "air". Have the competitor back down a "tad" to get the proper measurement with all tires making contact with ramp or ground.
We have always used the centre of the rim to the centre of the rear rim to get our wheelbase. It just has to be "close" when you measure.
Of course if this ramping is entirely for fun with no prizes and no bragging rights, than do whatever you want:D
Ramping....
« Reply #12 on: June 22, 2005, 06:09:17 PM »
Thanks Tom for all the tips!!!! It sure will help!!!!  :D
I think this even is just for fun... :D  :D  :D
It will be from noon to 14:00 on Sat. the 5th @ National 4WD on 46th ave. SE.
Chris ... I see you there? please bring the calculator!!! :lol:
Offline Elsifer
Ramping....
« Reply #13 on: June 22, 2005, 09:16:39 PM »
Yup, I'll be there!
And I'll bring the calculatrice, trust me, even I need it!
Cheers
Chris
VA6CPL
Jeepless....
Offline jeepsucks
Ramping....
« Reply #14 on: June 23, 2005, 08:29:58 AM »
what if my jeep cant make it up the ramp because you guys make it to steep will i get laughed at?
this jeepsucks up every nickle I make.
