Author Topic: Bent C on front JK axle  (Read 2230 times)
Offline LAHAL
« on: June 16, 2015, 08:49:39 PM »
So, I tried being proactive and decided to replace my ball joints. My mechanic told me after that I had bent the upper C on my front axle. So it wouldn't drive straight. It drives like crap now, to the point that I don't think it's save. Has anyone had this problem, I could really use the help fixing this.
Offline raf2379
Re: Bent C on front JK axle
« Reply #1 on: June 16, 2015, 09:15:26 PM »
did it drive like crap before you took it to the mechanic?
Offline LAHAL
« Reply #2 on: June 16, 2015, 09:16:27 PM »
No
Offline raf2379
« Reply #3 on: June 16, 2015, 09:30:28 PM »
hmm did the mechanic possibly bend your inner C trying to press out the ball joints, and is covering his arse trying to tell you it was bent. its strange that it drives like crap afterwards and not before. who did you take it to?
« Last Edit: June 17, 2015, 12:35:09 AM by raf2379 »
Offline LAHAL
« Reply #4 on: June 16, 2015, 11:55:04 PM »
Chanda
Offline raf2379
« Reply #5 on: June 17, 2015, 12:44:12 AM »
ok, if its bent it could have happened on a hard hit offroad, only way to fix it is get a new inner C welded in. check for other bent components such as axle tube, and check the caster. do you want to attempt to fix this your self? or get a shop to do it?
Offline LAHAL
« Reply #6 on: June 17, 2015, 08:24:46 AM »
I wish I had the skill needed to fix this, but i'll probably have to get a shop to do it.
« Reply #7 on: June 17, 2015, 08:32:13 AM »
Its pretty common to bend those. Unfortunately the new axles have really weak C's. Shitty deal.
It shouldn't really drive "that" bad though. I guess maybe its a matter of perception, but if it really is driving so bad, I'd look into the rest of the alignment and the condition of the other steering components. Seems like something else might be out.
