Purchased this 1985 Eagle Nov 1, 2015 off kijiji.
Had no brakes, leaked like a siv and ran ok. Got it home, put it in the garage. So began the dissecting. Bit of back ground first. I am a Journeyman HD Mech and Millwright. So going beans deep. At first, how the snow ball started it had the el-cheapo plastic tappet cover. Broke that coming off. Chasing more leaking, in the ended up pulling everything, engine, trans, tcase front diff and even ripped apart the rear diff. Engine, did a refusrbish-reseal, new aluminum tappet cover and comp cam. Trans, adj bands, flush and reseal. tcase, insp and reseal. Front diff, insp and reseal. Rear axle, new wheel bearings seals, lunch box locker, pinion seal. Now the drivetrain back in and the eagle running, had to rebuild the carb(carter POS), looking to do an upgrade. Replace the muffler and a section of the exhaust. The POS motorcraft ignition is giving me grief, so I ordered an HEI setup. Also dealing with some front end issues, but figuring it out. Thank you Internet. But would like, a NP229 for low gear and neutral for towing behind vehicle.
SO. My Eagle adventures have been interesting. Educational. But, I have been driving it for the last month, it is fun, gets a lot of looks.
I will post pics later.
