Author Topic: 2005 tj lifter noise  (Read 1253 times)
Offline zeek
« on: April 03, 2016, 08:57:58 AM »
hi folks...has anybody run into a 4.0L when it is the 1st start up in the morning have lifter noise (only 1 or 2 of them) and once it warms up it goes away...it almost sounds like a lifter that isn't pumping up.  i am just trying to get some feedback to know how to correct this. the reason why it is so concerning is the jeep only has 67.000 original on it
thanks
zeek
Re: 2005 tj lifter noise
« Reply #1 on: April 04, 2016, 09:23:36 AM »
Late model 4.0's had a lot of issues with cam lobes wearing down really bad. The also had issues with the oil pump drive/cam position sensor.
Cams in the late model's from 01 and up were very shitty as it was. Dodges continued attempts to meet emission regs forced them to use very restrictive cams that used long exhaust duration profiles to increased exit burn temps.
It would not be surprising for you to have bad cam wear, making it difficult for your lifters to pump up.
A cam swap on a good running 4.0 is beneficial as it is. Likely even more so in your situation.
You can read up on line. There were lots of cases of cams losing entire lobs in their first year.
