Author Topic: Building new house and need to check clearance in garage.  (Read 1504 times)
StblJmpr
« on: June 23, 2005, 09:52:13 AM »
Alright.  I've got a TJ that I want to put a 5.5-6" lift with 35s.  What is the full height of the vehicle at this point?  Will I be able to get it into the garage with a 7' tall garage door?  Should I get the builder to make the garage door 8' just to make sure?  I was thinking that a lift and larger tires would result in about 8.5" extra vehicle height. (6"lift + 2.5" tire to axle increase)  Does that work out about right?  If someone has a similar setup, do you have problems with height of the garage door?
Dragonmaster
« Reply #1 on: June 23, 2005, 09:46:26 PM »
get the 8' regardless, it is soo much easier to manouver odd things in and out of, and you won't regret it.
