Author Topic: Cherokee 4.0 oil filter adapter  (Read 1599 times)
Offline Fredduck
  • RIDE ON
« on: April 10, 2016, 11:39:19 AM »
Have any of you guys removed or repaired the oil filter adapter on a 4.0 in a '90's Cherokee?
The centre bolt is being a biotch, and there is a good oil leak from the block to adapter O-ring.
Any tips or tricks?
Re: Cherokee 4.0 oil filter adapter
« Reply #1 on: April 10, 2016, 12:47:16 PM »
Probably easier to pull the entire motor and replace it with a 4bt.
« Reply #2 on: April 10, 2016, 01:34:34 PM »
Changed mine. Bolt was like  locktight in. Bigger snipe bar.
Offline Fredduck
  • RIDE ON
« Reply #3 on: April 10, 2016, 05:09:24 PM »
I only have 1 of those, and it's being used right now  ;D
« Last Edit: April 10, 2016, 05:39:46 PM by Fredduck »
