Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
Trading Post
Jeep Stuff For Sale
Anyone with a Rubicon looking to go to 4.56 gears?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Anyone with a Rubicon looking to go to 4.56 gears? (Read 1444 times)
Ddub1973
Budget Lift
on:
May 18, 2016, 08:49:39 PM »
So here is what I am thinking about doing....
I have a 2013 JKUR and I had 4.56 gears installed by 4 Wheel Parts in 2014. I love the gearing but as most of you know I am stripping it and hoping the Jeep Truck comes out soon....
I am looking for someone with a 2012 - 2016 Rubicon that currently has 4.10 gears.
What this would be is a direct swap of both front and rear axles (housings and all).
My factory housing has the following:
- G2 Dana 44 JK Front Reverse 4.56 Ratio Gears
- G2 Dana 44 JK Rear 4.56 Ratio Gears
- G2 Dana 44 JK Rubicon Front Master Install Kit
- G2 Dana 44 JK Rubicon Rear Master Install Kit
- Alloy JK Dana 44 Red Outer Axle Tube Seals
- Front and Rear Lower Control Arm Skids
http://www.4wheelparts.com/Drivetrain-Differential/JK-Dana-30-44-Red-Outer-Axle-Tube-Seals.aspx?t_c=12&t_s=237&t_pt=101188&t_pn=ALY11105
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Front-Reverse-4-56-Ratio.aspx?t_c=12&t_s=237&t_pt=5092&t_pn=G%2f22-2051-456R
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Rear-4-56-Ratio.aspx?t_c=12&t_s=237&t_pt=5092&t_pn=G%2f22-2052-456
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Rubicon-Front-Master-Installation-Kit.aspx?t_c=12&t_s=237&t_pt=5094&t_pn=G%2f235-2051
http://www.4wheelparts.com/Drivetrain-Differential/Dana-44-JK-Rubicon-Rear-Master-Installation-Kit.aspx?t_c=12&t_s=237&t_pt=5094&t_pn=G%2f235-2052
http://www.4wheelparts.com/Armor-Protection/Lower-Control-Arm-Skid-Plate.aspx?t_c=79&t_s=467&t_pt=3545&t_pn=SYN8012-03
These above listed parts are $1,444.73 including tax.
This will work for an automatic, manual, 2 door or 4 door.
My housing has also had the front wheel bearings replace within the last year, as well I will be installing new front upper and lower ball joints within the next week. I change the diff fluid regularly and only use Amsoil Synthetic.
I am looking for $1,600 for this deal. With labour and shop supplies you would be over $2,500 for this at the shop.
I also bought the 4 Wheel parts warranty which should be transferable but that would have to be confirmed.
Please do not attempt to low ball me or make negative comments.
Please call or text as that is the fastest way to get me.
4O3-681-2O4O
Thanks,
Dwayne
Logged
DDUB OIIIIO
2013 JKUR
Ddub1973
Budget Lift
Re: Anyone with a Rubicon looking to go to 4.56 gears?
Reply #1 on:
May 20, 2016, 02:02:33 PM »
BUMP......OBO...
Logged
DDUB OIIIIO
2013 JKUR
FiEND
Talks waaay too much!
Wrecking Ball
Reply #2 on:
May 20, 2016, 09:14:38 PM »
you don't need to bump after two days. maybe after it leaves the first page or after a month...
Logged
Ddub1973
Budget Lift
Reply #3 on:
May 20, 2016, 09:16:38 PM »
Thanks for the tip, but if you notice it was more so that I could add OBO.
Logged
DDUB OIIIIO
2013 JKUR
Ddub1973
Budget Lift
Reply #4 on:
May 28, 2016, 12:00:27 PM »
Ok so I found out the axle housings are the same from 2007 - 2016.
So anyone with those years that are interested I am going to drop to $1,300. That is basically half price.
Logged
DDUB OIIIIO
2013 JKUR
Print
Pages: [
1
Go Up
« previous
next »
Trading Post
Jeep Stuff For Sale
