Author Topic: 350 conversion ? I have a deal for you !  (Read 1275 times)
Offline Bigbadmudmachine
« on: October 03, 2016, 12:29:39 PM »
Out of my YJ
For sale is a new 350 cu in Chevrolet crate engine with under 12000km on it.complete and ready to roll .
Tbi with air raid cold air intake. Performer tbi intake manifold  , headman headers , oil pan , msd ignition and  Aluminator 350 HP
Module radiator with electric fan . Includes starter Engine Type:?Chevy Small-Block V-8
Complete duel exhaust , engine mounts
Displacement (cu. in.):?350
Bore x Stroke (in.):?4.000 x 3.480
Block ?Cast-iron with four-bolt main caps
Crankshaft ?Nodular iron
Connecting Rods ?Powdered metal steel
Pistons ?Cast-aluminum?Camshaft Type ?Hydraulic flat tappet
Camshaft Lift (in.):?.435 intake / .460 exhaust
Camshaft Duration (@.050 in.):?212° intake / 222° exhaust?Cylinder Heads ?64-cc chambers
Valve Size (in.):?1.940 intake / 1.500 exhaust
Compression Ratio:?9.1 nominal
Rocker Arms ?Stamped steel
Rocker Arm Ratio:?1.5:1
Water Pump ?Cast-iron, long-style
Recommended Fuel:?92 octane
Ignition Timing:?Base 10° BTDC, 32° Total
Maximum Recommended rpm:?5500
Balanced:?External
 Also have excellent front and rear seats and a complete set of autometer  guages to fit YJ which includes tach , speedo, water temp, trans temp , fuel , oil pressure and volts . Rear  door , roll bar , windshield , hood , power steering , brake mater cylinder
Engine has less than 12000 k on it  and looks new
Reply to [email protected] please as I don't always get on here enough and i will reply quickly
« Last Edit: October 04, 2016, 04:18:24 AM by Bigbadmudmachine »
Offline pooljunky
Re: 350 conversion ? I have a deal for you !
« Reply #1 on: November 21, 2016, 11:00:42 PM »
Hey do you have a price on this?
« Reply #2 on: November 22, 2016, 10:25:36 AM »
"Reply to [email protected] please as I don't always get on here enough and i will reply quickly"
Try that.
