Author Topic: Hypertec Max Energy Programmer  (Read 879 times)
Offline shawnicles
« on: December 20, 2016, 09:48:14 PM »
I Have a Hypertec Max Energy programmer. Bought it for my previous Jeep but it barely does anything for my TJ. This programmer would be better for someone with a JK.
$200 and it's yours.
Here is a link
http://www.4wheelparts.com/Performance- ... n=HYP32501
Here are some of the things it's able to do for the JK
Speedometer\Odometer Correction For Gears 2.82:1, 3.07:1, 3.21:1, 3.42:1, 3.55:1, 3.73:1, 3.92:1, 4.10:1, 4.56:1, 4.88:1, 5.13:1, 5.38:1
Speedometer\Odometer Correction For Tire Sizes 22.5 - 44 inches 1/4 inch increments
Top Speed Limiter 25 - 75 MPH in 5 MPH increments, 81 to 255 MPH to match speed rated tires
Rev Limit -500 to +500 RPM Above or Below Stock Value
Cooling Fans Stock, 180 degrees F, 195 degrees F
DTCs Read and Clear
The features listed below are only available on the "2007-2010 Jeep Wrangler - Enhanced Features" platform. This platform can be installed by updating the programmer over the internet with the update software and choosing the 2007-2010 Jeep Wrangler - Enhanced Features platform.
Idle RPM adjustment for 4Lo, Normal, and Winch 700-1800 RPM in 50 RPM increments
Throttle Response settings for 4Lo, Lo, Mid, and High -50% to +50%, in 5% increments
Throttle Body Settings for Viper or Stock Throttle bodies
On-The-Fly turn on cooling fan regardless of coolant temp.
Tire Pressure Monitoring System (TPMS) Threshold Adjustment 2 psi to 100 psi for All tires, front tires, or rear tires
On-The-Fly Differential Locking Control In All Modes (Rubicon Only)
On-The-Fly Instant Idle Override 500 – 2000 RPM, in 50 RPM increments
On-The-Fly Traction Control Enable\Disable
On-The-Fly Tire Pressure Monitoring System (TPMS) Disable
shawnicles
New Member
Has thanked: 0 time
Been thanked: 0 time
Real Name: Shawn
