Author Topic: Gobi Stealth Rack & Sunroof Insert for 4 Door Jeep Wrangler  (Read 1141 times)
Offline J4Willys
« on: January 12, 2017, 07:47:20 PM »
Selling my Jeep, buyer is not interested in the Gobi Stealth Rack, so I'm selling it separately. No issues at all with the Gobi Rack, it's been amazing. Highly recommended.
Sale Includes:
- Gobi Stealth Wrack w/ Drivers Side Ladder ($2340 brand new)
- Gobi Stealth Sun-Roof Insert (makes for full roof rack) ($265 brand new)
- Gobi Wind Deflector ($220 brand new)
*NO DRILLING required for install*
Link to my Kijiji ad: http://www.kijiji.ca/v-view-details.html?adId=1230883740&posted=true&adActivated=true
Purchased for $2825 CAD brand new + shipping. Asking $2200 obo.
Jeep JK 4 Door vehicle luggage roof rack with sun roof opening.
* Weight 88 lbs
* Length 90 inch, Width 54 inch
* Black texture semi-gloss Powder Coat with Gray epoxy anti-rust undercoat.
* 16.26 sq ft. (with sun roof opening), additional cargo space of 10.4 sq ft can be added with sun roof insert available upon request. Sun roof insert load limit 150 lbs.
* Load limit 300 lbs.
* Cargo deck 3/4 inch 9 gauge expanded metal welded in place.
* 1 1/4 inch 14 gauge, 1 inch 16 gauge welded tubular frame with (2) 1 1/8 inch O.D. welded in accessory attachment cross bars.
* (1) Front light bar attached to base OEM windshield outer frame. Used to support front end of roof rack by means of four 3/8 inch carrage bolts. Black powder coated with gray epoxy anti-rust undercoat.
* (2) Rear 1/4 inch formed steel support towers black powder coated with gray epoxy anti-rust undercoat attached to OEM body and frame.
* (1) Rear support roll bar attached support. Tower and underside of roof rack. Black powder coated with gray epoxy anti-rust undercoat. NO DRILLING
* 4 Place front light bar for use with up to 2.5 inch x 6 inch oval or rectangle off road lights.
* 2 Independent rear light for use with up to 2.5 inch x 6 inch off road lights.
* Stainless Steel hardware.
* Over all height of Jeep Wrangler JK with OEM factory tires and Gobi Stealth rack is approximately 78 inch. *
Gobi Jeep JK Roof Rack Sun roof insert.
* Weight 35 lbs
* Cargo deck 9 gauge 3/4 inch expanded metal welded in place.
* Usable cargo space 10.4 sq ft.
* Stainless steel hardware.
* 16 Gauge 1 inch welded tubular frame.
* (4) 1/4 inch steel wedge clamps held in place by (4) 3/8 inch brass inserted thermal plastic knobs.
Can check out a Canadian retailer for the products here:
http://www.northridge4x4.ca/shop/gobi-jeep-jk-4-door-stealth-roof-rack
-- and --
http://www.northridge4x4.ca/shop/gobi-jeep-jk-roof-rack-sun-roof-insert
-- and --
http://www.northridge4x4.ca/shop/gobi-jeep-jk-wind-deflector
Please feel free to ask any questions you may have.
« Last Edit: January 12, 2017, 07:54:42 PM by J4Willys »
