Author Topic: K & N Air Intake  (Read 1353 times)
Offline dljaljevic
K & N Air Intake
« on: August 31, 2017, 08:49:59 AM »
Hey everyone, can't find the answer to this anywhere.
Im planning on buying a K&N intake, model #57-1553.
I realized that this is for a JK, but for the 3.8L engine (07-11)
I have a 2013 with the 3.6L engine.. do you think this will fit on? Or if not
is there any way to retrofit on? Anyone done this before? Thanks
Offline dljaljevic
Re: K & N Air Intake
« Reply #1 on: August 31, 2017, 08:59:11 AM »
Did some more research and I dont think it would be possible to fit, I think the mounting points are different, as well as the length/shape of the pipe is different.
« Reply #2 on: August 31, 2017, 04:16:38 PM »
Dude. Just add the stickers. That's where all the HP gain comes from anyways.
Offline MattMan
« Reply #3 on: August 31, 2017, 08:27:35 PM »
Yep, I wouldn't waste your time/money. I just added the K&N filter to the stock box. Relatively cheap at CTC...
[/size][size=78%]I'd put the rest towards upgraded exhaust. [/size] 8)
MattMan
« Reply #4 on: September 01, 2017, 02:13:34 AM »
And I think the engine is different.
A re-usuable filter in the stock box is probably a better bet. Its more protected, and if your jeep sees more than stock roads it would be better to have some water and gunk protection over the open element variety.
Offline hamrtime
« Reply #5 on: September 12, 2017, 12:56:16 PM »
if you go with exposed "oiled" filter get the little pull overs for them - think they are called prechargers (from K&N), you can see through them, first few times out without one noticed mud on filter dries then "draws" the oil out of filter - not what you want - with a precharger it doesnt.
'89 yj - bought new - almost got my moneys worth
'97 xj - family cruiser now
