Can't get the rear track bar back aligned
slanktapper:
So my lift is just a 2" on my tj. The instructions didn't say to disconnect the track bar(?) but in order to get the coil out I needed to.
Anywho now I can't seem to line up the track bar with the hole it needs to go in.
I've let the passenger side down as low as I can (disconnected the shock and sway bar was already off) and jacked up the other side and it's still not enough.
Jacked up: https://i.imgur.com/O84p3cs.jpg
Level: https://i.imgur.com/RMnpz0L.jpg
Any ideas
Kanueh:
Try a big ratchet strap to the frame and axle to suck it into place.
slanktapper:
--- Quote from: Kanueh on September 20, 2017, 11:00:55 PM ---Try a big ratchet strap to the frame and axle to suck it into place.
--- End quote ---
Ah that would be way easier than that come-along I couldn't figure out how to attach.
I'll try this first thanks!
slanktapper:
--- End quote ---
Yep that did it. Took two straps but I was able to MacGyver it in the correct way. And the wheels appear to be properly spaced too.
Kanueh:
For future jobs where you have to take the track bar off, I always put a tie strap on tight before I take it apart.
Navigation
[0] Message Index
[#] Next page
Go to full version
