Author Topic: .  (Read 2917 times)
Offline dljaljevic
« on: January 10, 2018, 10:26:55 AM »
« Last Edit: June 29, 2018, 04:26:47 PM by dljaljevic »
Re: Body vs Suspension lifts
« Reply #1 on: January 10, 2018, 01:32:51 PM »
What model Jeep do you have? A TJ or JK can be lifted by putting spacers on top of the coil springs. Probably pick up a set for less than $200
« Reply #2 on: January 10, 2018, 02:08:01 PM »
wouldnt the bigger tires increase my ground clearance?
Unless you get new axles, bigger tires are the ONLY thing that will actually increase your ground clearance.
That said, there's a reason that most of us opt for a suspension lift instead of a body lift. A good suspension system will increase your ability to keep the tires in contact with the ground....and that's the name of the game.
Offline dljaljevic
« Reply #3 on: January 10, 2018, 03:47:49 PM »
« Last Edit: June 29, 2018, 04:26:56 PM by dljaljevic »
« Reply #4 on: January 11, 2018, 02:32:13 AM »
You can clear 33s with a body lift. I've done it, but i don't recommend it being done again. Along with the body lift comes more body roll, your shift linkage likely wont work correctly anymore, your radiator will hang out from the bottom and look horrible because everything behind the body will stay in place, and its just not the best way to go... To clear tires sure, but save up a little, and clear the tires the best way with a suspension lift. In the end, that will treat you right in the long run.
Offline MattMan
« Reply #5 on: January 11, 2018, 06:30:26 AM »
 On my two-door JK  I’m running a 3 inch rough country suspension lift the last couple years and it’s treated me well. I’m also running 32’s.
 The kit was relatively affordable at around $380 US off of eBay but of course exchange rate was a little better than as well.
MattMan
« Reply #6 on: January 11, 2018, 11:32:31 AM »
W squared: I see, any kits that you suggest? Or is a suspension lift necessary for 33" tires to be cleared
As far as I know, the only thing that you'll need to clear 33's on a JK is a bit of trimming and wheels with appropriate backspacing for larger tires.
The JK Rubicons come from the factory with 32" tires...and I actually saw someone run 35's on a stock height JK one time....but that involved a LOT of rubbing, so that's not necessarily something I'd suggest.
« Reply #7 on: January 11, 2018, 02:32:28 PM »
Cut, regear, lockers, bigger tires, and beadlocks. Done. I wish I had listened to the old timers when I was building.
Offline dljaljevic
« Reply #8 on: January 12, 2018, 02:20:15 PM »
« Last Edit: June 29, 2018, 04:27:08 PM by dljaljevic »
Offline dljaljevic
« Reply #9 on: January 12, 2018, 02:21:27 PM »
« Last Edit: June 29, 2018, 04:27:30 PM by dljaljevic »
« Reply #10 on: January 13, 2018, 06:04:42 PM »
Would i need to regear for 33/34? Lockers and beadlock would be nice but i dont think thats in the budget just yet.
Do you know what gear ratio you have?
Offline dljaljevic
« Reply #11 on: January 18, 2018, 09:35:09 AM »
« Last Edit: June 29, 2018, 04:27:23 PM by dljaljevic »
« Reply #12 on: January 18, 2018, 10:06:56 AM »
I think 3.21. I was looking at the 2.5" tera lift, but ill have to get an adjustable track bar and a better tire mount for the back (stock one cant hold 35's i guess) and then ill probably need a new rear bumper too haha. Not sure what to pick for tires yet
Tire's are always a hot topic. There's so many to choose from. Be honest with yourself on what your goals are for this jeep. If you really want it to perform off-road and want a mud tire you will sacrifice your street/winter performance. A good aggressive AT can do a lot off-road but will never be as good as a mud tire. Tire size is up to you, a 285/75R17 is about 34" tall and fits well, but if I recall you have 16" rims, there should be a size that fits your rims fairly well too.
If you keep your lift height to about 2" you can keep your stock track bars, it's not ideal, adjustable track bars make a big difference in my opinion. But good coils and shocks are very important as well.
Offline dljaljevic
« Reply #13 on: January 18, 2018, 12:29:07 PM »
« Last Edit: June 29, 2018, 04:27:17 PM by dljaljevic »
