Author Topic: Graveltravels tinworm CJ 7  (Read 6630 times)
Offline Graveltravels
Re: Graveltravels tinworm CJ 7
« Reply #15 on: April 18, 2018, 04:15:27 PM »
« Reply #16 on: April 18, 2018, 04:19:47 PM »
So, cutting up my poison Spyder corners to fit around the tube fenders. I have to fill in and weld up the drivers side fuel door, and cut one in the passenger side. I'm also planning to get the tailgate bolted in, and the supports welded in.
Running the exhaust, and getting it to dump out the back, the po had it dump in front of the rear axle, right in the brake lines and housing. And, my FI-Tech showed up!! So I'll be running a new fuel line for that. I also picked up a 700r4, and ordered the adaptor for the Dana 300. Figured I may as well get it done while the body is off.
« Reply #17 on: April 21, 2018, 02:05:14 PM »
A little cut, patch and weld, and YJ corner armour becomes CJ corner armour!
« Reply #18 on: April 21, 2018, 02:07:14 PM »
And same for the sliders. No weld tho!! Just some cut and grind. And now off for a textured powder coat. I've had the textured coat on a ARB bumper for the last three years, and it's stood up better than anything else I've ever used.
« Reply #19 on: April 21, 2018, 02:08:40 PM »
And I got my 700r4. Overdrive, here I come!! Ordered tha advance adaptor kit for it, should see that next week.
Offline Kanueh
« Reply #20 on: April 21, 2018, 02:56:23 PM »
I’ll be in Red Deer in Thursday again if you want me to grab them.
2008 JKU Rubicon
« Reply #21 on: April 24, 2018, 09:05:52 AM »
YJ tub becoming a CJ tub. Brackets welded in, hinge holes drilled. Mocked up, and fits like it belongs. I'll be drilling a couple pieces of 2" flatbar, tacking nuts to it, and putting it in the body channel, for a bit more hold and strength.
Offline slanktapper
  • Rob
« Reply #22 on: April 24, 2018, 11:35:45 AM »
Looks great!
Tall Rob
Sold: Silver 06 Rubicon - 35"
Current: 92hp True selectable 4x4, Spooled rear diff, Electric front locker, 30" Mud Tires, Snorkel. Warn Axon 35s.
« Reply #23 on: April 27, 2018, 06:29:25 PM »
New springs hung up front. And boomerang shackles ordered. Always something else, isn't it?
« Reply #24 on: May 01, 2018, 01:26:19 PM »
And on to the rears. And of course, bolts breaking, bolts not moving. And then a jeep buddy showed up to give a hand, and broke down. So we worked in his jeep instead
« Reply #25 on: May 02, 2018, 09:48:51 PM »
Rear boomerangs and rear bumper. Done. Pulling transmission and transfer case Friday, and hopefully installing the new set up over the weekend. Then time to drop the body back on.
« Reply #26 on: May 06, 2018, 09:42:52 AM »
TH350/NP205 pulled.
« Reply #27 on: May 06, 2018, 09:44:34 AM »
Spare Dana 300 set up for a 700r4 now. Delayed a bit on reinstall, my GM mechanic buddy cannot get a look at it til Tuesday.
« Reply #28 on: May 06, 2018, 09:45:11 AM »
So I sat on the deck, and mounted Krawlers to Beadlock's.
« Reply #29 on: May 08, 2018, 10:14:39 PM »
